Noise Margin
- Re: Noise Margin
Re: Noise Margin
01-01-2010 7:00 PM
Re: Noise Margin
03-01-2010 10:16 PM
Re: Noise Margin
05-01-2010 7:38 PM
Re: Noise Margin
05-01-2010 8:16 PM
I can reset it for you, but this also resets the 10 day training period.
If you want it doing gimme the nod and I'll sort it now.
Re: Noise Margin
05-01-2010 10:18 PM
Re: Noise Margin
05-01-2010 10:20 PM
Re: Noise Margin
06-01-2010 11:10 AM
You may find that the router resyncs when the noise margin changes anyway, otherwise one reboot a day mid-morning when the noise is lower would be best.
Re: Noise Margin
06-01-2010 1:22 PM
Re: Noise Margin
06-01-2010 1:31 PM
Re: Noise Margin
07-01-2010 12:03 AM
Edit: What should i do now to try and get a stable sync? It doesn't say on my routers stats that i have lost sync for days, but my sync has gone from 7040 today to 4960. If i reboot my router tomorrow, will it have any adverse affects on my snrm ?
Re: Noise Margin
07-01-2010 1:56 PM
Re: Noise Margin
08-01-2010 10:26 PM
Re: Noise Margin
08-01-2010 10:30 PM
Re: Noise Margin
08-01-2010 11:23 PM
Protocol: G.DMT Annex A
Downstream Rate: 4416 kbps
Upstream Rate: 832 kbps
Channel: Fast
Current Noise Margin: 10.0 dB (Downstream) 11.0 dB (Upstream)
Current Attenuation: 41.7 dB (Downstream) 24.0 dB (Upstream)
Current Output Power: 19.7 dBm (Downstream) 12.3 dBm (Upstream)
Re: Noise Margin
08-01-2010 11:53 PM
