Noise Margin Reduction Request
- Re: Noise Margin Reduction Request
25-09-2022 7:02 PM
Hi, is it possible for my noise margin to be set to 6db (downstream)? Previously it was set to 6db down and up (hub one), I have recently acquired the hub 2 and the noise margin seems to stay at around 7.9. I'm hoping this change will increase my downstream data rate which is sat at 60mbps and does not seem to want to go above this. Current line speed on my Plusnet broadband homepage is 80mbps and is the same on the BT wholesale checker
Data rate:15.561 Mbps / 60 Mbps
Maximum data rate:15.565 Mbps / 68.249 Mbps
Noise margin:5.8 / 7.9
Line attenuation:8.3 / 16.4
Signal attenuation:8.3 / 17.9
Many thanks for your time.
Labels:
Message 1 of 2
(933 Views)
1 REPLY 1
28-09-2022 9:45 AM
Hey @Nathan_H,
Thanks for reaching out to us and I'm sorry we couldn't get back to you sooner. It looks like this request has already been processed, so it'd be best to give it a few days and let us know if anything changes on your end. If you're still having issues with the speeds, just drop another message onto your thread and we'll be happy to review further ![]()
Message 2 of 2
(850 Views)
