No wireless connection
gcdsmith
Mobile phone will not connect to internet. Error message is incorrect password.
2 REPLIES 2
Fixes: 585
Re: No wireless connection
Double check that you have the password correct. It's on a card on the back of the router https://www.plus.net/help/broadband/router-user-guides/
Note it is case sensitive and make sure you aren't confusing zero and O, also one and lower case L
If that doesn't help, is your phone only capable of 2.4ghz ?
willcutforth
Fixes: 113
Hey there @gcdsmith is it all resolved now or do you need me to look into it?
 Will Cutforth
