No network from 2am to 5pm
- Re: No network from 2am to 5pm
19-02-2021 4:41 PM
The lights stay on solid green.
Have reset the router twice.
I have the WiFi analyzer installed but it just says the same, you are not connected to the internet or no network found.
Plusnet are sending me a new router.
19-02-2021 4:44 PM
OK @arichards - we shall see what the new router does.
19-02-2021 5:05 PM
@arichards wrote:
Can't understand how I can watch YouTube with no internet ?
Depends on what you are viewing it on. If on a mobile are you watching via data usage instead of the router's WiFi.
19-02-2021 5:15 PM
I've taken a screenshot from plusnets own site and the DSL addressees are different?
19-02-2021 5:18 PM
Sorry, meant DNS.
19-02-2021 5:30 PM
The DNS servers ending in 150 used to be among the authoritative Plusnet DNS servers, but I believe they were decommissioned some years ago.
I believe the ones you have in your router settings are correct.
19-02-2021 5:36 PM
@corringham They are correct, but are the alternative servers, the primary ones are 212.159.13.49, 212.159.13.50
19-02-2021 5:51 PM
It could be worth trying the primary ones then?
19-02-2021 6:06 PM
Yep.
19-02-2021 8:47 PM
I can't change them, no options in the router settings.
20-02-2021 5:17 AM
Gone again.
2.20 till 5.
20-02-2021 7:16 AM
Apparently it has to be done via telnet, but I shouldn't bother - having checked mine, they are the same and I don't have the issue.
To be honest, because this 'error' is so predictable, it has got to be some time-related setting somewhere, but I admit I have no idea where.
20-02-2021 10:46 AM
It is just possible it is a REIN problem causing interference at that time - is there any nearby electrical equipment that is set to operate at that time?
20-02-2021 5:32 PM
Nothing powers on as far as I am aware.
These logs show synchronized to server every hour except from 2 to 5 ?
21-02-2021 2:50 AM
2.12 down again !!!
How can I still watch YouTube over my WiFi with no internet
Surely someone can help.
Really getting me down now as the internet is my only contact with outside world.
