No internet connection
Tomleeder
Lost WiFi connection last night and can’t get it back tried everything recommend on the help page and still no luck
7 REPLIES 7
willcutforth
Fixes: 113
Re: No internet connection
I'm here @Tomleeder ! All caffeinated up and ready to go! Sorry to hear you are having issues with the broadband, has anything changed in the property at all? Can you pop over some pics so our lovely superusers and myself can help you as the line test says it could be a home set up issue.
 Will Cutforth
Tomleeder
Nothing has changed in the house has been working fine for the last 2 years
willcutforth
Fixes: 113
Glad nothing has changed! Which telephone socket do you have? If you're not sure, please can you check on What type of master socket have I got? | BT Help ?
Are you using the Plusnet router as well?
 Will Cutforth
Tomleeder
We have the single socket one with the micro filter.
Yeah we are using the Plusnet hub 2 router
Fixes: 378
@Tomleeder Is it possible to post your current version of these three Hub pages, please?
3.Hub2 broadband.png3.Hub2 broadband.png5.Hub2 technical.png5.Hub2 technical.png8.Hub2 Status.jpg8.Hub2 Status.jpg
Tomleeder
Sorry but how would I find that information please ?
Fixes: 378
Log into the Hub and navigate to the requested pages?
