No connection
- No connection
No connection
21-08-2024 11:18 PM
Hello, my hub is shining the orange lights and It has no connection with the internet. I try to rest it but same things happened . Try to send a message to report it , but the bot reply me and said it can’t find my phone/boardband account. Really need some helps thanks.
Labels:
Message 1 of 4
(1,162 Views)
3 REPLIES 3
Re: No connection
23-08-2024 3:43 PM
Message 2 of 4
(1,014 Views)
Re: No connection
23-08-2024 3:44 PM
Thanks!
Message 3 of 4
(1,011 Views)
Re: No connection
23-08-2024 4:09 PM
Do you still have a landline or are you on FTTP or SOGEA (internet only)? The bot has been known to have problems with these.
Message 4 of 4
(1,004 Views)
