No connection, but have DSL sync!
- Re: No connection, but have DSL sync!
- « Previous
- 1
- 2
- Next »
28-10-2011 10:47 AM
I had similar authentication problems a couple of weeks ago. Apparently there was something amiss with my line. I seemed to have got that sorted, but then just a few days later I encountered quite a strange and somewhat worrying issue as I reported here Possibly that was an exception peculiar to my system, but I was able to access the net again after opening "Network Connections" (in XP) and selecting the option to Repair my connection.
Might be worth a try?
Message 16 of 22
(415 Views)
28-10-2011 1:11 PM
thanks, but it certainly looks exchange or switch related at pn or bt's end. as i can connect and authenticate successfully using the bt test user account. using my in pn credentials the lcp tunnel fails according to erx27.sheffield5.
there was an issue about three days ago with erx26 that caused loss if service for some people in my area code (but not me). this looks like exactly the same problem but with the neighbouring router/switch.
will check the status of my ticket shortly.
Message 17 of 22
(415 Views)
28-10-2011 1:46 PM
and as if by magic, bt fault 34235 states a problem with sheffield5 5 edge route switch 27.
it doesn't have my area code listed as affected but ill bet its connected. im away from home right now so can't test though.
also funny how ut says it started at 10:45 this morning. try 8am yesterday morning. nothing like fudging the stats eh bt?
Message 18 of 22
(415 Views)
28-10-2011 1:47 PM
@chesterfield,
I've just had a look at your account/ I'm not sure if you were aware that the connection seems to be intermittent, in fact from what I can see it's back up at the moment. You should have a response from the faults team ASAP.
Message 19 of 22
(415 Views)
28-10-2011 2:46 PM
I've not been aware of it being intermittent. i ha e reported a couple of times or so yesterday eve and this morning but never connected to plusnet, just the bt test. will see if all is well when i get home
Message 20 of 22
(415 Views)
28-10-2011 8:09 PM
Returnd home and all is now fine. I guess it must have been the ERX27 that BT identified after all.
Now to research if the "pro" add on to the current prodcts will give me the same usenet speeds as my current "plusnet pro" package. As there is no turning back.... gulp...
Message 21 of 22
(415 Views)
31-10-2011 10:38 AM
I think you'll find the new pro just as effective, and probably cheaper
Message 22 of 22
(415 Views)
- « Previous
- 1
- 2
- Next »
