No broadband service
robgroomcbr
I have had no connection since 11:30 this morning in Waterlooville, Hampshire.
Is there an issue that plusnet don't know about?
9 REPLIES 9
Mustrum
Fixes: 81
Re: No broadband service
Why are you posting duplicate threads?
You would be better off reporting a fault.
Moderators Note
Duplicate post removed
robgroomcbr
I have been trying all day but no answer
Mustrum
Fixes: 81
Have a read of the Help section.
Is your phone line working?
https://www.plus.net/help/report-a-problem/broadband/
SpendLessTime
Fixes: 86
@robgroomcbr if you want a member of staff to help, it will be much quicker to phone Plusnet. These forums are very much understaffed so any live issue is best dealt with by phoning in.
Mustrum
Fixes: 81
Or texting as per  my link!
robgroomcbr
I don't have a phone line.
The router is solid orange and there's a red flashing b symbol.
I have switched router off, left it for an hour , still not working, I have also done a factory reset that didn't fix anything.
RealAleMadrid
Fixes: 68
@robgroomcbr You do have a phone line, unless you are on FTTP. Perhaps you don't have a phone to connect to it. You appear to have line fault, do you have a mobile phone? If so why not try the text fault reporting method as advised by @Mustrum  in message #4
Quickest way - troubleshoot by text
Text HELP followed by your landline number to 07800008121.
e.g. HELP 01234567891
(charges may apply at your standard rate)
  • We’ll run tests on your connection to find out what’s going on
  • If you need an engineer, we’ll text you in 15 mins to book a slot
  • If you don't need an engineer, our award-winning UK based support team will call you within 30 mins to help sort the problem
  • Service available Mon-Sun: 8am to 8pm
  • Outside of these hours please see our Help and Support guides, and if you’re still having trouble we’ll pick up your message when we’re open
robgroomcbr
I have never had a landline and do not know what the number would be.
Is there any way of finding this info ?
Mustrum
Fixes: 81
You could look in the member centre, look at the email PN sent you at the start of the contract, or borrow/buy a phone and ring 17070 which will announce your number.
