No ADSL service; any thoughts?
- Re: No ADSL service; any thoughts?
21-01-2008 11:57 AM
It is obvious that my friends loss of service is a basic line fault, causing the snr to rise to a level where the router will not sync, but why do PN staff keep on insisting there is nothing wrong with the service? How can they tell? Why won't they (quickly) despatch an engineer to my neighbours home to diagnose the fault?
Any ideas; anyone (especially PN staff!!)
21-01-2008 12:12 PM
Would you be able to PM me his username please, so I can have a look at the account? I'll be able to advise a lot better once I've had a look at the fault ticket.
Many thanks,
25-01-2008 6:55 PM
My question is; why don't they pursue a fault until it is resolved instead of leaving a customer in the dark?
All the ticket note says "We would like to inform you that your Help Assistant Question [ xxxxxxxxxxxx] has now been returned to the BOT - DSL Logged Faults - No Syn pool. A member of our Support Team will investigate your issue as soon as possible." Then: "EU has had engineer visit please check notes, EU advises engineer did some work at the exchange but the fault still exists, please contact BTW again if necessary"
Thats meaningless to a customer. Cant PN use laymans terms to explain what is happening?
Graham
31-01-2008 9:38 PM
All PN's suggestions have been tried, before they suggested them, a BT engineer has called and confirmed what we already knew.
Has anyone got BT's managing directors phone number?
Graham
01-02-2008 12:13 AM
"We would like to inform you that your Help Assistant Question [ xxxxxxxxxxxx] has now been returned to the Broadband Operations Team - Digital Subscriber Line Logged Faults - No Synchronisation pool. A member of our Support Team will investigate your issue as soon as possible." Then: "End User has had engineer visit please check notes, End User advises engineer did some work at the exchange but the fault still exists, please contact British Telecom Wholesale again if necessary"
I would guess that PlusNet Customer Support are following up on this problem. Get your friend to ring them (0114 296 5198 / 0845 140 0200), or add more questions to the ticket. Customer support statistics are at http://www.plus.net/supportpages.html?a=212 to find a quiet time to ring.
Orbrey did ask you to send him a Private Message containing your friend's username. Did you send this to him along with your friend's ticket numbers? Send him another Private Message if necessary.
01-02-2008 4:27 PM
I am in a constant dialogue with orbery about this; he has had the PM with the user name since a fortnight back & he has been most helpful. It is not PN that we are upset with; Its BT!!! Even though PN are part of BT they seem helpless in dealing with the problem. It is simply unacceptable that this service has now been off for three weeks.
Quite simply their (BT) attitude to ADSL faults is appalling. The fact that they then frighten off most people with a unpleasant reminder about having to pay £163.00 + VAT if the fault turns out to be the customers is just one of many complaints. Another is that some of the engineers they (BTW) send out are not even computer literate. (Thats the admission some of the engineers i have had to deal with have made, [and there have been not a small number of them], not my conclusion based on the fact they couldn't fix the problem, but based on remarks made such as; " I'm getting a bit long in the tooth for all this computer malarkey)
One possible this particular reason this service has died could be quite simple; it may have been upgraded to ADSL max which will not work over a long reach line at the limit of ADSL. At the moment I am trying to find out if this was done or not.
Cheers
Graham
05-02-2008 5:17 PM
Vis message:
To: #############
Subject: PlusNet - Question has been amended or escalated
Your username: ################
A member of our Support Team has updated Question [number ############ ], or has passed it to another department for further action.
The following comment was added to the Question
(INTERNAL)
message left for customer confirming engineer notes.
spoke to SMC who have now passed case to DSL Max Performance team to consider downgrade - awaiting response..
Regards,
A###############
13-02-2008 3:03 PM
PN now say waiting for a long line team to get involved.
13-02-2008 3:06 PM
It is possible that a broadband service may not be possible on your telephone line. the Long Line team will now investigate and will probably need to send out an engineer to test your line further to see if any service can be received.
I appreciate that the service did work in the past so hopefully they'll be able to locate the cause of the fault.
More updates as we get them though!
17-02-2008 11:37 AM
Any one have any idea why this kind of problem has taken over six weeks and is still not sorted out?
28-02-2008 8:08 PM
They cant make up their minds whether or not to make any repairs as they cost about £20 per section.
Any one have any opinions on this, as to what we can do to restore a service?
01-03-2008 2:37 PM
Why did it take them 8 weeks to find the fault?
Thanks BT.
