New fibre speed
- New fibre speed
Re: New fibre speed
26-03-2012 10:08 AM
Re: New fibre speed
26-03-2012 1:31 PM
Re: New fibre speed
26-03-2012 3:35 PM
Quote from: devil5882 before i went onto fibre i had a steady speed no matter what time of day it was no matter how many things were conected.
Yes, but that was when the speed of your connection was < 7Mbps. The amount of devices connected to your router won't make any difference as long as they're idling and not using the connection when you're running speed tests. As already mentioned though, you're going to struggle to achieve consistent throughput speeds on fibre if relying on a Wireless connection. I know you've tried using a wired connection but I'm warranting a guess that the vast majority of speedtest results you've linked to in this thread were carried out over the wireless link?
I've checked your traffic management profile, BT profile and sync rate from this side and it all checks out. You're line is synchronised at 39.9Mbps so across a wired connection I would expect you to get speeds around the 37Mbps mark.
I can see you've raised a fault and been asked to run the BT speedtester too over a wired connection? The results from that are very low but I can only see evidence that you completed the first test? Were you not prompted to complete any more?
Also, what operating system/version of Windows are you using?
Re: New fibre speed
26-03-2012 4:30 PM
Re: New fibre speed
26-03-2012 4:48 PM
Re: New fibre speed
26-03-2012 5:05 PM
The ticket is still on your account, it's currently sat with our Faults Team.
You didn't answer my question about the BT Speedtest?
Re: New fibre speed
26-03-2012 5:15 PM
Re: New fibre speed
26-03-2012 9:34 PM
I typically get 55Mbps across my Powerline adapters but noticed things were a tad slow this evening. Did some gateway hopping and found that my speeds were seriously lacking on certain gateways ...
ptw-ag02 - 3.37Mbps
pcl-ag07 - 54.76Mbps
ptn-ag04 - 3.78Mbps
pcl-ag02 - 3.51Mbps
ptw-ag03 - 4.12Mbps
pcl-ag08 - 4.78Mbps
ptw-ag02 - 55.92Mbps (different end-point to last time?)
So if you disconnect/reconnect enough times and are lucky to hit the right gateway then you may well see a significant improvement. Best way to disconnect/reconnect (assuming you're using the Netgear router we supplied) is to just hit the 'Apply' button on the WAN settings page (where your broadband username and password are entered).
I'll make sure this is looked at tomorrow though because something definitely looks amiss to me ...
Re: New fibre speed
26-03-2012 10:25 PM
Re: New fibre speed
27-03-2012 8:27 AM
Re: New fibre speed
27-03-2012 9:55 AM
Chris was having similar problems to me last night before hopping around and settling on a gateway that gave him favourable speeds. We've just checked his connection and he's on a Collindale end-point too.
@devil5882, you disconnected/reconnected around 10.45pm last night and having just checked you're also connected to a Collindale end-point. Did you notice a marked improvement after the disconnect/reconnect?
We're currently looking at other recent reports of problems to see if they're consistent with the theory that the issue is isolated to customers connected to our Faraday host-links ...
Re: New fibre speed
27-03-2012 11:58 AM
Since the AAISP graph showed packet loss ending around midnight my gateway hop may not have been what cured the problem (though it did seem to restore speed to normal).
Re: New fibre speed
27-03-2012 12:45 PM
Re: New fibre speed
27-03-2012 1:10 PM
Re: New fibre speed
27-03-2012 1:24 PM
