New User - Couple of Questions!
- Re: New User - Couple of Questions!
02-03-2009 9:12 PM
Hello all!
Just migrated over to plusnet today onto the pro package. My speed is up around the 7 meg mark which is pleasing after having some erratic speeds with adsl24 and all of entanets issues.
However, I have noticed my Ping has basically doubled from 22ms to 41ms. I had interleaving off under adsl24, could this now be back on?
Also, I have been having a look at all the various tools and I had a quick look at broadband usage. Since I got in from work I have only been doing some general surfing as well as a few speedtests. My usage is saying 43% Web and 57% Other. What comprises 'Other' then?
Message 1 of 6
(999 Views)
5 REPLIES 5
02-03-2009 9:17 PM
You need to raise a ticket to get interleaving switched off. It seems to be put on automatically
Message 2 of 6
(450 Views)
02-03-2009 10:15 PM
Ok. Is it worth doing so this early on with a new connection. I had it switched off on the old one so I presume it should be fine to have it switched off on this new connection without waiting for the training period to end?
adie:quote
adie:quote
Message 3 of 6
(450 Views)
02-03-2009 10:23 PM
Think it should be fine, you might even have the option to switch it off here https://portal.plus.net/my.html?action=myconnection&?membermenu=connectionsettings
Message 4 of 6
(450 Views)
02-03-2009 10:51 PM
If it was fine before, it'll be fine now.
Raise a ticket and PM me with the ticket number and I'll get it sorted when I get into the office tomorrow morning
Message 5 of 6
(451 Views)
03-03-2009 8:53 AM
Many thanks Jameseh.
I will PM you the number.
Cheers.
Cheers.
Message 6 of 6
(452 Views)
