New Plusnet customer: I can get WiFi calling, but every website shows err_connection_close
cobb1es
Hi
I recently signed up to Plusnet and setup the router. I can get Wifi Calling fine on my phone, but everywebsite I goes to displays "unexpectedly closed the connection. err_connection_close"
I dont understand it. Like I say, Wifi calling is fine, but I cant browse the internet on my phone or my laptop.
Any ideas?
15 REPLIES 15
Fixes: 357
Re: New Plusnet customer: I can get WiFi calling, but every website shows err_connection_close
Which router do you have - the Hub2?
Your comment 'can't browse the internet' does not make sense - you must be able to, to post here.
cobb1es
Yes jab2, the new one (Hub2)
Fixes: 357
See my amendment to post #2
cobb1es
Haha, I should have said (sorry): Im using my neighbours connection to post this.
Fixes: 357
Sorry for the delay, but very quickly, before I get back to what I'm supposed to be doing - do you mean you can use your mobile data, but can't connect via the router?
cobb1es
Sorry, back on my neighbours wifi again...
I was fiddling about with this last night. Something very odd is happening:
My phone and laptop says its connected to the new plusnet connection fine. I can make Wifi calls on my phone, but whenever I visit a website it says 'err_connection_close'.
The even weirder thing is that Youtube works! And Google works! But everytime I click on a google result, the subsequent website displays  'err_connection_close'! This happens on both the laptop and 2 mobile phones.
Things I have tried:
- reset router/restart router
- flush the DNS cache on my laptop
- gone into Network Connections (on my laptop) > Internet Protocol Version 4 (TCP/IPv4) > “Obtain an IP address automatically” is selected and "Obtain DNS server address automatically" is selected.
Its very odd that I can connect to Youtube and Google fine - across all devices - yet no other website works!
What do you think?
Fixes: 357
So - you can make calls on your phone, understandable as phone calls rely on the phone masts for the signal, not you internet connection.
If you can connect to YT/Google , then my initial thought that your circuit was somehow misconfigured is wrong, but why other sites give that message, I do not know.
I think I'll tag a couple of more experienced/cleverer people.
@Dan_the_Van  / @MisterW  ?
cobb1es
Thanks @jab1 for your input so far.
I live out in the sticks, so no phone coverage. This is why Im sure the calls are being handled over wifi.
Its so odd that Google/YT work fine - across all devices - but no other website does. Its almost as if all ip addresses have been blocked on the router apart from Google/YT.
As I say, the router was only setup a few days ago.
Ill see what others have to say. Thanks.
Fixes: 558
Sounds like a browser issue to me. What browser are you using ? and can you try a different one on the laptop perhaps ?
cobb1es
Yes, I thought it may be a browser (although doesnt explain why its also affecting phones).
Ive tried Brave, Chrome and Firefox. Im stumped!
bobpullen
Fixes: 330
@cobb1es - try a factory reset of the Hub Two by inserting something into the pinhole at the rear of the device until the status light flashes green. I think I've spotted what may have been wrong.
5 mins or so after the factory reset, I'm hopeful you'll find there's no longer an issue.
RobPN
Fixes: 13
@jab1
WiFi calling uses the home Internet connection (i.e. via the router) not a phone mast!  Wink
Fixes: 357
@RobPN OK - Senior moment - the OP must then have a mobile service that allows it, I did mean to ask earlier who their mobile provider was.
cobb1es
Wow! Its just suddenly started working!!! Ive done nothing (not factory reset or anything since last night).
How very strange! I will never understand how wifi/internet connections work. Its black magic as far as I can see! Smiley
Thanks everyone for your comments, apologies to waste your time. But all is well that ends well! Smiley
