New Hub 2 in Bridge mode no internet
FIXEDTopic Options
- New Hub 2 in Bridge mode no internet
10-12-2023 12:15 PM
I just installed my new Hub 2 in bridge mode as a straight replacement for a BT open reach modem. I use a Asus RT-86U as my router . I believed that setting bridge mode would not have any consequences but on connecting up to my router I can't access the Web. The router hangs on "Reconecting to internet"
but can't. Status shows disconnected. Can anyone suggest what I've done wrong ? I didn't change anything on the router.
Fixed! Go to the fix.
Message 1 of 3
(1,365 Views)
2 REPLIES 2
10-12-2023 12:19 PM - edited 10-12-2023 12:24 PM
@Rod2023 welcome to the forum
It should work, make sure you use LAN 1,2 or 3 (NOT the WAN) to connect to the WAN port of the Asus router
HTH
Edit: the Hub light should be a pink colour for bridge mode
Message 2 of 3
(1,361 Views)
Re: New Hub 2 in Bridge mode no internet
10-12-2023 12:26 PM
Thanks very much.I had it connected to the Wan port.!! Now fixed.
Thanks again
Thanks again
