New Fibre Install
- Re: New Fibre Install
29-11-2013 1:36 PM
29-11-2013 1:51 PM
My guess is that it's actually a faulty PSU but I'd be reluctant to just replace it with the ADSL one in case the Fibre router actually has a fault which bricked the PSU!
29-11-2013 1:58 PM
29-11-2013 2:00 PM
29-11-2013 2:01 PM
29-11-2013 2:11 PM
If i succesfully flash the old adsl one, what details do i need to get it online as i assume they are normally preconfigured with username/passwords etc.
29-11-2013 2:17 PM
If the flash is successfull on the ADSL one it might self configure since it may still be registered on your account. If not you need to put in your PlusNet username & password
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
29-11-2013 2:59 PM
29-11-2013 8:24 PM
30-11-2013 12:33 PM
That's good. I thought it probably would. As a matter of interest, did the ADSL one have a USB port ?
Quote flashing the fttc firmware over my adsl router did indeed work, thanks for your help
01-12-2013 6:46 PM
01-12-2013 7:33 PM
At least we've confirmed that the fttc f/w works without a USB port.
01-12-2013 7:36 PM
Adam
01-12-2013 7:43 PM
Support can do this over the phone, or if you wait until the DCT guys are back in action in the morning, they will do it for you.
01-12-2013 8:16 PM
