New Asus dsl N55U need help Please.
- New Asus dsl N55U need help Please.
Re: New Asus dsl N55U need help Please.
27-04-2014 9:24 AM
I'm wondering if you both have the UK model of modem/router AND the UK firmware.
A few months back, when I was looking for my ideal ADSL modem, it became apparent that some manufacturers produce modems that are optimized for the broadband signal characteristics for different countries infrastructure, and therefore it is vital that you get the correct version of hardware and firmware for your region in order to get a good connection.
I just wonder if you (and the other thread) have inadvertently bought imported devices which don't work optimally on BT lines.
27-04-2014 10:41 AM
The automatic set up page is straight forward - it lets you set a router password, detects your ADSL connection, asks for your PN username/password, allows you to set a WiFi SSID/password.
As for the WiFi - it's proven to be one of the best performing routers for wireless. So there must be something wrong if you can't get good wireless signal.
Can you post the system log to let us see what's going on with regards to your connection?
27-04-2014 11:29 AM
27-04-2014 11:36 AM
You said you were connected PPPoA, which indicates it's for an ADSL connection. But now you're talking about the BT router/modem, which indicates FTTC (PPPoA is wrong for this).
27-04-2014 11:47 AM
Quote from: got2getatan When I put the WAN connection details User name/Password I am put the my Plusnet Account user name/PW which support told me to.
Your PPPoA password should be IDENTICAL to that used to login to the Plusnet Member Centre
Your PPPoA username should be as shown for "Login Name" in these Connection Details
It is worth checking the above just to be sure, as Plusnet CS have in the past told me the WRONG details when I was trying to diagnose a fault.
27-04-2014 12:00 PM
27-04-2014 12:22 PM
27-04-2014 12:27 PM
27-04-2014 4:20 PM
27-04-2014 4:25 PM
Asus are excellent routers, regarded as one of the best.
27-04-2014 4:57 PM
27-04-2014 6:09 PM
Though having personal experience with this router I'd say take it back my first N55U failed and my second one now has a hard time detecting line attenuation correctly since BT changing which cable i used to get to exchange. (long line here) reviews I've read seem to state its better on short lines. Wireless performance for me was faultless though.
Give the above a try if that still doesn't work just get shot of it.
Edit: forgot to mention SRA is enabled by default for some reason
28-04-2014 7:03 PM
28-04-2014 8:43 PM
Glad you got it sorted. I will have to buy one now
13-05-2014 6:52 PM
Watch this space or not as the case may be.
