Setting up VPN within Router?
john10001
Is it possible to set up a VPN within your router so that no matter what devices connect to the internet it will be behind the VPN? Or do PlusNet routers on Fibre not offer this?
1 REPLY
Fixes: 224
Re: Setting up VPN within Router?
you could get a new router with DD-WRT and configure it to use OpenVPN, but the PN supplier router won't do that.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
