Network/Hub Keeps Disconnecting
Fixes: 387
Re: Network/Hub Keeps Disconnecting
Just the username field in total.
dom_trig
Fixes: 387
I suggest you run the faults bot - you have a bit of 'headroom' as your line attenuation (distance from the green cab) is short, but you shouldn't be having so many DSL drops.
dom_trig
ill see what they say. thanks for your help so far
Fixes: 251
There are a couple of observations here...
  • When was this contract last renewed?  This is clearly a 40/10 provision and for a good while, services are supposed to be on a fast as you can go profile ... which is much fast than the 40/10 reported
  • Given that you have so much SNRM head room, frequent disconnections would seem to point conclusively to an issue with the d-side circuit
If you have had a lot of such issues, then a d-side lift and shift might be appropriate.  I thing this needs staff escalation.
Fixes: 387
I think you are probably correct, @Townman . Wonder what the bot will come up with?
dom_trig
Apparently thats all i can get. I have struggled to get past the first line of plusnet tech defence so far i.e. get to the advisor and the usual have you turned it off spiel. Is there a better route?
dom_trig
Renewed in August, better speeds than i was on before! Rural living for you
Fixes: 387
Looking at the Technical Log, @dom_trig , you should be good for an 80/20 connection. Do you still have a land-line phone connected?
That 'advisor' is useless, and needs sacking.
dom_trig
No, landline was ditched. Ill try them again tomorrow evening and see where i get to. Ill report back in case it helps anyone else (assuming they can sort it)
Fixes: 387
OK - thought that might be the case if you renewed this August, but it was just an idea.
Trying them again will be a waste of time - you'll just get the same stupid question.
@Townman Can you escalate?
Fixes: 251
Check the Openreach service projection for your location.  Those stats clearly show better is possible … but with the state maybe not stable.
This needs second line support.
@Gandalf any chance of a shove in the right direction please?
dom_trig
Says i can get faster but probably limited due to location. Hopefully full fibre in the next year. Ill download csv again next time disconnects
Fixes: 387
@dom_trig Just for my interest, can you attach the results from here: https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome - hiding your address?
dom_trig
