Net drop
- Net drop
Re: Net drop
10-09-2009 9:17 AM
Quote from: Jameseh Hiya,
I can see that you disconnected at 05:10 and reconnected 13 minutes ago.
RADIUS reports the connection drop as an administrative reset - could be standard maintenance on your exchange at that time in the morning.
Thank you Jameseh for looking. Right, well, for starters it can't be me coz i wasn't up at 5.10! But i did reboot the router at the time you claim. Why would standard maintenance cut me off and if it is that why would it do it 5x a day nearly or 3x in one hour and at all times of the day. Initially it started being around tea timeish and then got later and earlier. Does anyone really have an answer that will totally resolve this annoying problem?
Ive also just noticed in my router stats that my downstream data rate has finally changed from 5952 to 6272 but the noise margin is still at 12.2 and upstream up to 24, why has that changed suddenly???
Re: Net drop
10-09-2009 9:24 AM
Variable sync rates are not unusual. Quite often you might notice a bit of a change when you reboot your router. Generally these will be best earlier in the day when there's less noise present on the telephone line.
As for why your connection is dropping, there could be many different reasons. I'd initially suggest swapping out the router and filter and making sure that you're wiring into your master socket (sorry, I can't remember what you've tried so far!). If it's still dropping after that, then raise a fault.
Re: Net drop
10-09-2009 9:53 AM
Re: Net drop
10-09-2009 9:54 AM
Re: Net drop
10-09-2009 9:58 AM
Re: Net drop
10-09-2009 9:59 AM
Are Home Phone Faults guys are pretty spot on.
Re: Net drop
10-09-2009 10:06 AM
Re: Net drop
10-09-2009 10:09 AM
Re: Net drop
10-09-2009 10:15 AM
Re: Net drop
10-09-2009 10:56 AM
This web page is not available.
The web page at null might be temporarily down or it may have moved permanently to a new web address.
More information on this error
What problem, when i take out my net from the phone line and reconnect would cause this??? I'm really stumped now
Re: Net drop
10-09-2009 12:03 PM
Re: Net drop
10-09-2009 12:10 PM
When you said "all light flashing" what exactly did you mean?
We'll bottom this if it kills us, which it prolly will!
Re: Net drop
10-09-2009 12:28 PM
Quote from: nozzer You might have tried this, but disconnect everything that's NOT related to your broadband, just leave the router plugged in, and try again. Sound to me as though you have a bit of kit (another phone?) which might be up the spout. If you have the so-called master socket installed in the house, plug the router directly into that socket behind the faceplate.
You're right, I have lol! Another phone which might be up the spout????? What exactly do you mean by this?? I think my definition of 'up the spout' may not be the same as yours lol. I use the master socket anyway coz my secondary in 6ft high in the hallway! If i plug in behind the face plate i dont get any internet connection at all, or last time i tried there i didn't, i'll give it another go though.
Quote from: nozzer When you said "all light flashing" what exactly did you mean?
The wireless light (flashing), adsl light (solid) and net light (flashing) were all as they would be if my computer were connected and working online but the web pages wouldn't load.
Quote from: nozzer We'll bottom this if it kills us, which it prolly will!
Lol, but your help is appreciated thank you
Re: Net drop
10-09-2009 12:34 PM
Sound as though you have tried everything. Does the wiring behind the faceplate go directly out of the house into an external box of some kind?
And.. sometimes dis/reconnecting often confuses the PC... when in doubt try rebooting the pc! Do this first.
Out of interest you are using dialup at the moment?
Re: Net drop
10-09-2009 1:05 PM
Secondly, my home phones are wireless.
I live in a block of flats, i'm assuming the wiring goes to a cupboard called BT on the ground floor of the flats (it's a 2 storey building).
I tried re-booting the PC when it failed to connect properly this morning and it didn't work and i'm on PN's unlimited broadband package.
