Net drop
- Net drop
Re: Net drop
08-09-2009 5:59 PM
Re: Net drop
08-09-2009 6:10 PM
(Just re-read that and it said "my life was a shambles etc.." which is also probably true!!! )
Re: Net drop
08-09-2009 6:14 PM
I don't actually turn off my modem at night anyway, usually too tired to remember. Suppose as long as its staying connected it'll be ok if it speeds up in time. Just wish everything would be stable, line, speeds etc
Re: Net drop
09-09-2009 8:37 AM
Type Interleave
Status No Defect
Downstream Upstream
Data rate (Kbps) 5952 448
Noise margin (dB) 9.9 23.0
Output power (dBm) 19.7 11.9
Attenuation (dB) 37.0 23.0
The downstream noise margin has dropped to 9.9 from 12.6, thats good right????
Re: Net drop
09-09-2009 8:49 AM
Quote "BT Wholesale are also proposing to provide a customer controlled SNR reset facility. This will be made possible by making a facility that is being developed for BT Wholesale Operation's people, accessible to all customers.
If a customer issue has been resolved by making changes to the end customers environment then a fasttrack recalculation of the line will be possible (by request) without the need to report a fault into BT Wholesale. It is expected that this service will be made available on eCo and B2B from the 9th December 2009."
There's a trial coming up in a couple of months which we've asked to take part in. Note this is 20CN and not 21CN (yet).
Re: Net drop
09-09-2009 8:53 AM
Good reference.. http://www.kitz.co.uk/adsl/linestats.htm
Re: Net drop
09-09-2009 9:49 AM
Quote from: Jameseh This might be of interest:
Hmmm, and this is there way of saying what exactly, we all know what BT are like. Wonder if it'll help any. I read about 21CN last night, we are meant to get it in this area between Oct and March 2010.
My noise margin is fluctuating at the moment, gone from 9.9 to 9.7 to 10.1. Not had any net drops so thats good. Just have to see how things go and hope.
Re: Net drop
09-09-2009 9:51 AM
Re: Net drop
09-09-2009 9:59 AM
Re: Net drop
09-09-2009 10:06 AM
It will fix "stuck" SNR problems.
Re: Net drop
09-09-2009 10:33 AM
Re: Net drop
09-09-2009 8:04 PM
Re: Net drop
10-09-2009 8:39 AM
Re: Net drop
10-09-2009 8:42 AM
I can see that you disconnected at 05:10 and reconnected 13 minutes ago.
RADIUS reports the connection drop as an administrative reset - could be standard maintenance on your exchange at that time in the morning.
Re: Net drop
10-09-2009 9:12 AM
