Need help
Ja5
Need help
My internet was working fine. Then it cut off solid orange light.
I've turned it off and on, reset with a paper clip now tried to get on to the hub manager but it won't come up.
But now I've noticed my password for my hub manager has rubbed off from the back of my router. I've had the router for 6years.
Any help please
13 REPLIES 13
Fixes: 388
Re: Need help
@Ja5 IIRC, there was a plastic card with the details supplied with he hub - have you still got it? If not, call Support in the morning - they should be able to help.
Ja5
Re: Need help
No I lost it when we moved house.
Will they be able to give me the password
Fixes: 388
Re: Need help
They should be, providing you get an agent who knows what they are doing.
ExForce9
All Star
Fixes: 11
Re: Need help
... or if you get a clueless agent, their default answer to everything is to ship out a new router Cheesy
Fixes: 388
Re: Need help
might be useful, if the OP  has a Hub1.
Ja5
Re: Need help
I really hope not as I need internet.
Expecally for my sanity from my kids
Ja5
Re: Need help
I'm not sure what hub it is.
But it's rectangle white with a circle and the light is around that. If that helps. I've never had a problem before
Fixes: 388
Re: Need help
sounds like a Hub2 - but I may be wrong.
Ja5
Re: Need help
I've just googled it. It's definitely a hub2
Fixes: 388
Re: Need help
OK. When you  call, if the agent is stumped, maybe giving them the serial number (starts with a '+') will help. Are you back online  with it?
Ja5
Re: Need help
No still no internet. I'm using my mobile data
.ive had to connect it to my TV to watch it. My dose all electronics need to be connected to wifi these days,
Fixes: 388
Re: Need help
In that case, try running the faults bot - sorry can't give you the link as it appears PN are updating the site.
ExForce9
All Star
Fixes: 11
Re: Need help
