Need help
- Re: Need help
Need help
06-10-2026 9:01 PM
I've turned it off and on, reset with a paper clip now tried to get on to the hub manager but it won't come up.
But now I've noticed my password for my hub manager has rubbed off from the back of my router. I've had the router for 6years.
Any help please
Re: Need help
06-10-2026 9:12 PM
@Ja5 IIRC, there was a plastic card with the details supplied with he hub - have you still got it? If not, call Support in the morning - they should be able to help.
Re: Need help
06-10-2026 9:18 PM
Will they be able to give me the password
Re: Need help
06-10-2026 9:21 PM
They should be, providing you get an agent who knows what they are doing.
Re: Need help
06-10-2026 9:29 PM
... or if you get a clueless agent, their default answer to everything is to ship out a new router ![]()
Re: Need help
06-10-2026 9:31 PM
might be useful, if the OP has a Hub1.
Re: Need help
06-10-2026 9:36 PM
Expecally for my sanity from my kids
Re: Need help
06-10-2026 9:38 PM
But it's rectangle white with a circle and the light is around that. If that helps. I've never had a problem before
Re: Need help
06-10-2026 9:40 PM
sounds like a Hub2 - but I may be wrong.
Re: Need help
06-10-2026 9:43 PM
Re: Need help
06-10-2026 9:47 PM
OK. When you call, if the agent is stumped, maybe giving them the serial number (starts with a '+') will help. Are you back online with it?
Re: Need help
06-10-2026 9:49 PM
.ive had to connect it to my TV to watch it. My dose all electronics need to be connected to wifi these days,
Re: Need help
06-10-2026 9:52 PM
In that case, try running the faults bot - sorry can't give you the link as it appears PN are updating the site.
Re: Need help
06-10-2026 9:54 PM
