Need help with router 2
Madalex24
I have a hub 2 and my set up is that I have a master socket 5 and plusnet router. I was told I need asdl cable to plug it in broadband port but when I plug my ethernet cable to connect it to my pc, it glows orange when I plug it the wan port. But my pc can't see the router. Any help please
6 REPLIES 6
Fixes: 386
Re: Need help with router 2
If you are on FTTC, the cable is plugged into the DSL port, not the WAN.
Madalex24
When I take the cable out of WAN the router flashes orange
IMM
Fixes: 386
So plug it into the DSL port - see the set up details given here: https://www.plus.net/help/broadband/router-setup-guides/hub-two/fibre-no-phone/
Are you a returning customer?
@Madalex24
Did you resolve the issue?
You should NOT be connecting anything to the WAN that is for Full Fibre ONT connection, in this case flashing Orange means the Hub is not receiving a DSL signal
Tina11192
Fixes: 18
Hi @Madalex24 I'm so sorry for the delayed reply, do you still need any assistance with this? The advice given previously from @Dan_the_Van and @jab1  was spot on, I hope it was useful to you!
Cri Ignatti
