My speed gone lower [solved]
- My speed gone lower [solved]
Re: My speed gone lower
29-11-2009 10:25 PM
30-11-2009 2:54 AM
still dosent explain why the snr is so flat.
what old router is it that your using?
are you sure routerstats is pointing at the right place on your router
30-11-2009 3:05 AM
the router is a 2wire 1800hg, its faulty for the above ping times, pinging the router itself
im pretty sure routerstats is setup for it, i chose the correct router and the ip address to the router is right, so yea
i dont wana bore you with graphs but check these two its pretty amusing, 1 minute it runs PERFECTLY fine which i think is lies, and then it has a fit lol
30-11-2009 3:12 AM
EDIT. added what my snr is up to right now
30-11-2009 3:19 AM
notice bottom left thats the drops
30-11-2009 3:21 AM
was bout to post this to show you what happens when i log into my dg834g v4 and logout of it why routerstats is running
30-11-2009 3:25 AM
these error stats are probably unlikely aswel
30-11-2009 3:27 AM
dont think i answered your first question either, but no im not wireless never plan on goin wireless tbh
30-11-2009 3:30 AM
30-11-2009 3:38 AM
i wouldnt touch the belkins thoe had one for 3 days and took it back, awful web intreface that treated you like a child with the settings it let you at
the dg834's are now on th v5's thoe and dont have the broadcom chip in them
30-11-2009 3:43 AM
30-11-2009 11:33 AM
I just rang ADSL Nation to ask some questions and he was honest with me, he said first you should try the ADSL in the test socket, "if you see a change in sync speed or whatever then the faceplates will help, but if you dont theres no point wasting your money". So after hearing this, I decided to do it. Took some time to sort everything, but yeah right now I am connected to the downstairs socket (in the test socket).
Im not sure If I am happy or disappointed tbh, I was hoping those filters would sort my noise margin/profile/speed out but.. unfortunately (or fortunately), there is no difference at all from what I can see
So I think that rules out my wiring or what not?
I just wonder to myself now, is it still worth getting those filtered face plates or not? Perhaps all I really need is to get rid of this cheap router from PN (no offense, it was free) and grab myself a good one that will keep me a solid connection, and just hope this problem resolves itself overtime, naturally?
Or do I just buy everything.. 2 faceplates, router and a new set of cables etc.... Im just confused, I still dont even fully understand what my problem is, except for the fact that my profile is half the value it used to be, which is decreasing my download speeds by almost half of what they used to be aswel. Doh!
30-11-2009 11:45 AM
30-11-2009 11:58 AM
These are stats when using the usual socket that I use (upstairs)
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,208
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 20.5 / 35.0
SN Margin (Up/Down) [dB]: 19.0 / 14.5
These are stats when using the downstairs socket (The master(Using test socket too))
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,368
SN Margin (Up/Down) [dB]: 18.0 / 15.0
30-11-2009 12:07 PM
