My maximum boardband speed
- My maximum boardband speed
18-10-2013 11:14 PM
My boardband speed is slower than I expect it to be, is 2Mbps the highest speed I can get? I've listed the details of my connection below and attached images of my tests. Thank you for your time and help.
Service:
Plusnet Unlimited
Estimated line speed:
6Mb (This may vary between 5Mb and 7Mb) - Checked on 2013-10-15 23:37:42
Current line speed:
1.7 Mb
Regards
Jing Jing Tao
Re: My maximum boardband speed
19-10-2013 8:32 AM
20-10-2013 9:07 PM
Thank you for your reply, I checked my router, this is the information I got, does this mean 2.2 Mbps is the highest I can achieve? Thank you for your help.
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 2,200
Regards
Jing Jing Tao
20-10-2013 9:19 PM
*Edit - also, do you keep your modem on 24/7 or disconnect or reboot it frequently ?
21-10-2013 10:33 PM
I've attached all the information. We leave our modem on 24/7.
Regards
Jing Jing Tao
21-10-2013 10:57 PM
Your downstream SNR margin is close to the default 6dB (which is assumed in the maximum speed calculation) so you must have some high frequency noise/interference on your line. This could be because you have forgotten to fit an ADSL filter on one of the telephone sockets you are using or it could be because your internal telephone extension wiring is acting as a radio aerial and picking-up radio transmissions or it could possibly be due to some faulty electrical equipment in your house that is injecting high frequency interference onto your mains wiring which then finds its way onto your telephone wires. Providing the source of the problem is somewhere in your house, and it almost always is, then you can find and fix it if you are patient and persistent enough.
To begin, refer back to this thread http://community.plus.net/forum/index.php/topic,96155.0.html and connect your router to the Test Socket. You will not see any immediate effect on your speed but if you are on the right track then the statistics (as per your last post) will change for the better.
22-10-2013 7:54 AM
22-10-2013 11:03 AM
The number of errors being logged is pretty high so I'd agree with the next step being to try using the test socket. When the filter is plugged in to the test socket you need to check that there is no dial tone on any other telephone sockets. If you could post the link information again when it has been running like that for a few hours we'll take another look.
22-10-2013 11:14 AM
Quote Plusnet Essentials Fibre up to 38Mbps - £16.49 per month
Setup charge - free
Speed - up to 38Mbps down, up to 9.5Mbps up
Contract - no change to your existing contract period
Usage - 40GB (between 8am and midnight), unlimited overnight (midnight to 8am)
Router - free 3 port wireless
This product is the same as our FTTC Essentails Fibre product only with FTTP.
Plusnet Unlimited Fibre up to 76Mbps - £19.99 per month
Setup charge - free
Speed - up to 76Mbps down, up to 19.5Mbps up
Usage - Unlimited
Edit: For the OP, FTTP is where you are connected directly to your telephone exchange via a fibre optic cable. This supports speeds up to 330/30Mb and the advertised speed is what you get (there are no issues like noise on the line etc. which affect copper lines). Very few people in the UK have access to this technology and it is certainly worth it if you want/need a speed boost!
22-10-2013 12:40 PM
Im on the 78Mb Down / 19Mb Up
You might think these speeds are a bit low, But look to the server im connecting to, New York, 3450 Miles away
jim:quote
22-10-2013 1:02 PM
Quote from: AndyH Unless I am missing something, but why does the OP not upgrade to FTTP?
When you move to FTTC then BT will come to your house and fit a high-quality filter to your broadband socket. You can buy the same filter yourself for about £10. It is an interstitial filter so provided you have a normal master socket then no re-wiring is required to fit the filter. This filter would eliminate the vast majority of problems with conventional ADSL broadband, let alone fibre. Under the rare circumstances where this filter does not work (because the cause of the problem is outside the house and/or on the mains) then I would expect a lot of problems with fibre also.
FTTP. if it really is available, does not (AFAIK) involve fitting the filter I mentioned but I imagine the modem is still potentially subject to REIN. Or maybe not? I have a very bad switched mode power supply if anyone with FTTP wants to run tests.
22-10-2013 1:09 PM
22-10-2013 1:20 PM
22-10-2013 1:31 PM
22-10-2013 2:14 PM
I've had FTTP for a year now and it really is worth getting. If the OP wants a future proof technology, he should definitely upgrade and PN should be pushing it towards him.
