My Opinion
- My Opinion
Re: My Opinion
01-05-2009 10:44 PM
the only thing you can do now to improve stablity on your line more is to get a i plate / ADSLnation filter plate or just remove the extension wires that are on the face plate you remove to get at the test socket
theres a table on here that tells you what sync rate you need to maintain to get which bt ip profile http://www.kitz.co.uk/adsl/IPprofile.htm
gd luck and hope we manage to get you in the low 4 figure speed club soon
Re: My Opinion
01-05-2009 11:11 PM
I will try to do that, I am alrready looking into buying one of those plates. I will keep you posted as when there are any news...taaa M80
Re: My Opinion
02-05-2009 10:46 AM
If you take a set of stats say twice a day for a couple of days, a daytime one and one in the evening about 10/11pm ish, and post them here we can see whether everthing is going OK.
Re: My Opinion
02-05-2009 10:50 AM
It was me who disconnected the rubbish wiring not the OP
Re: My Opinion
02-05-2009 11:03 AM
Quote from: Anotherone If you take a set of stats say twice a day for a couple of days, a daytime one and one in the evening about 10/11pm ish, and post them here we can see whether everthing is going OK.
I will do what you are asking me...it will interesting to see what the result will be...Thank you!
Re: My Opinion
02-05-2009 12:50 PM
@ 12.45 pm
Broadband Line Status
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:00:16:48
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 1312 Kbps 448 Kbps
Noise Margin 9.3 dB 13.0 dB
Line Attenuation 62.0 dB 31.5 dB
Output Power 15.9 dBm 12.4 dBm
Re: My Opinion
02-05-2009 3:45 PM
yeah as oldjim has said the OP has not disconnected there unused extension wiring from the face plate.
but they have double filtered there phone and sky box tho
maybe the king can convince the op to remove the extension wire's from the face plate as there was a bit of an improvment in line stats when using the test socket
Re: My Opinion
02-05-2009 4:05 PM
OK Frangal, just to clarify then, where are you plugged in at present?
Now here is an important tip - when you need to swap filters, sockets, routers etc. power down your modem/router first and wait several minutes before unplugging the line. I would advise to avoid disconnections/reboots more than 5 times with an hour and leave it alone then for the rest of the day. Otherwise the exchange DLM may think you have a line stability problem and raise the target SNRM (Noise Margin) which will limit your sync speed. Unfortunately this may already have happened once, but we'll see how things progress.
I take it from what you've said you didn't disconnect any wires from the back of the removeable faceplate?
Don't forget, you need to leave the modem/router on continuously (not the computer).
Re: My Opinion
02-05-2009 4:09 PM
Quote A touch of sacasm ASBO
none at all intended.
i was hoping the queen would see the comment and give you an OBE for your services to ADSL
Re: My Opinion
02-05-2009 4:26 PM
Re: My Opinion
02-05-2009 10:22 PM
Quote from: Anotherone A touch of sacasm ASBO , ha Jim, sorry about that, reading this thread was interupted several times, so I'd forgotten it was you by the time I got to the end
At present I am plugged to the test socket. I ave removed the front panel and I am plugged to the test sockect. I have bought a ADSL Faceplate with built-in ADSL microfilter
but after having a look at it I better not touchh anything, I goin to see if I can find someone who can fit it for me, no idea with wires, plus behind the plate there are 2 black wires
and I dont know the purpuse of it... So as I have said I havent touched the wires, and I am plugged to the test socket.
I'm just thinking, what about if I use another router a Belkin G+ I bought before I joined PlusNet?...anyway here are the readings from tonight:
Broadband Line Status @10.20pm
Latency Type Interleave Line Up Time 00:09:48:30
Re: My Opinion
03-05-2009 4:50 PM
Date Download Speed Upload Speed
Today 16:41 1003 kbps (125kB/s) 378 kbps (47.3kB/s)
Today 09:21 692 kbps (86.5kB/s) 314 kbps (39.3kB/s)
Today 01:09 690 kbps (86.3kB/s) 363 kbps (45.4kB/s)
Yesterday 18:37 685 kbps (85.6kB/s) 367 kbps (45.9kB/s)
Broadband Line Status @ 4.42 pm
Latency Type Interleave Line Up Time 00:06:40:14
Line Rate 1344 Kbps 448 Kbps
Output Power 16.0 dBm 12.3 dBm
Re: My Opinion
03-05-2009 5:08 PM
Edit: Have you got a digital camera, you could take a picture of the wires to the rear of the faceplate and those black wires. I suspect I know what is there but would like to see. You can add the .jpg attachment using the additional options button below the reply box.
Re: My Opinion
03-05-2009 5:51 PM
Quote from: Anotherone You've lost sync there at some point - around 10.am. or the router was turned off overnight and switched on then.
You are right there...how do you know that?...Yes it happens quite often, I am conected to internet, and every so often the internet light goes off, and there is no way
I can connect again, so I have to shut down the router and after 5 seconds I will have to switch on again. I will take soe pictures and I will post the later.
Thank you!
Re: My Opinion
03-05-2009 6:53 PM
Quote Yes it happens quite often, I am conected to internet, and every so often the internet light goes off, and there is no way
just the internet light or also the dsl light?
