My Connection
- Interleaving?
- « Previous
- Next »
Interleaving?
02-08-2011 4:38 PM
Connection had been up for over 120 hours before my SNR was reset. I do quite a lot of gaming so I was wondering if maybe I could try with interleaving turned off? I am using a SpeedTouch 585v6 which is a very good router for holding connection and it seems to work well with gaming.
Router stats:
Uptime: 0 days, 0:11:41
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,304
Data Transferred (Sent/Received) [MB/MB]: 7.70 / 156.25
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 25.0 / 42.0
SN Margin (Up/Down) [dB]: 23.0 / 6.5
Vendor ID (Local/Remote): TMMB /
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 17,206
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 2
I know the uptime is only 11 mins, this is because I have just switched back to this router after using a different router. This is because this router seems to work better when I play online games.
Router stats:
Message 46 of 50
(291 Views)
Re: Interleaving?
02-08-2011 4:40 PM
Current line speed:
4 Mb
4 Mb
Message 47 of 50
(291 Views)
Re: Getting Interleaving Turned on Increased my SNR!
02-08-2011 4:46 PM
Topics merged - can you please keep your continuing saga in one thread to help Digital Care Team responses
Message 48 of 50
(291 Views)
02-08-2011 4:49 PM
Sorry about that oldjim.
Download Speed
3513 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 3513 Kbps
Additional Information:
Your DSL Connection Rate :6304 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
Download Speed
3513 Kbps
0 Kbps 7150 Kbps
Message 49 of 50
(291 Views)
Re: My Connection
03-08-2011 10:51 AM
Much better already!
Uptime: 0 days, 3:49:11
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,880
Data Transferred (Sent/Received) [MB/MB]: 24.48 / 261.20
Line Attenuation (Up/Down) [dB]: 24.0 / 41.0
SN Margin (Up/Down) [dB]: 22.0 / 6.0
Error Seconds (Local/Remote): 19 / 0
FEC Errors (Up/Down): 0 / 6,190,845
CRC Errors (Up/Down): 0 / 22
HEC Errors (Up/Down): 0 / 21
Message 50 of 50
(291 Views)
- « Previous
- Next »
