My Connection is Getting Slower and Slower
stevenwhit
My connection seems to be pretty flaky the last couple of months.  I had to switch over to Fibre from regular ADSL in April.  It's less reliable and seems slower than my old ADSL service i'd had with Plusnet since 2005.  Speeds are all over the place    Lots of disconnections too.🤔 🤔  Ive had uplink speeds as low as 200k 🤔
14 REPLIES 14
Fixes: 581
Re: My Connection is Getting Slower and Slower
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
If you are unsure about any of the above, please just ask
stevenwhit
Ok ive tried my best with these screenshots, unfortunately I don't have a computer with a ethernet connection, but did put the laptop next to the router. The Advanced Diagnostics BT speed test didn't seem to want to work here though (it didnt when i tested my speed before), it tried it quite a few times.
capture_001_13092023_140208.jpgcapture_001_13092023_142551.jpgcapture_002_13092023_143358.jpg
Fixes: 581
That's fine, the screenshot from the Hub 2 says it all! You have a major problem with the performance of your line.
The downstream seems to be capped at 19.999Mb as indicated by the very high SNR margin, the upstream speed is appalling but since the SNR margin is only 6db it would indicate a line problem is affecting it.
Are you connected directly to the master socket ?
Are there any extension sockets wired in ?
If you have the latest master socket , an NTe5C with a Mk4 faceplate, its probably worth unclipping the faceplate and connecting the router directly (using a DSL filter) to the test socket, then repeat the Hub 2 screenshot. It has been known for the faceplate connectors to be faulty.
stevenwhit
IMG_20230913_160234.jpgIt's connected directly to the mastersocket, there are no extensions. I did just take the faceplate off and plug it directly into the socket.   Here's what the router says with that setup
Fixes: 581
Ok, so basically no improvement, that eliminates any internal wiring as a cause, you have a fault on the line which is causing the low speeds. The downstream is way below the handback threshold (MGALS) and , as I said earlier , the upstream is diabolical!
You need to report a fault, which should get an Openreach engineer appointment to investigate.
In the first instance ( assuming you have a mobile ) then use the Troubleshoot by text facilility here https://www.plus.net/help/report-a-problem/broadband/
stevenwhit
OK, I don't know if this is relevant, BUT, CityFibre have been installing fibre across the town and recently they installed a tall telephone pole a few houses down, I noticed that the line from my house to the old pole behind it is draped across one of the rungs on the new pole.  Could they have damaged the line when installing the new pole?  I've attached a few pictures.
Fixes: 581
Your line looks a bit slack, so I would question what else have they done to it ? All the others still look correct.
If that was about when the speed started to drop, then its probably not coincidence!
Start by reporting a fault, and an Openreach engineer should spot that cable and check it out.
stevenwhit
UPDATE:  Have done the text based fault reporting.  This was the conclusion:
Hi, PlusNet Diagnostics bot here.  Our diagnostic testing has found a problem with our network.  We will arrange an Openreach engineer to investigate.  The tests indicate that Openreach will be able to resolve the problem without visiting your property.  You will not be charged.
No idea what kind of fault it is, but as it says it's with PlusNet, they ought to refund me my bill for the terrible broadband connection.🤔
Fixes: 581
Sounds like the cityfibre installation DID disturb your line.
stevenwhit
Do I get any notification from PlusNet about what work was carried out and when and if it's believed to be fixed?  I haven't heard anything since reporting the initial fault on Wednesday 13th.  Connection is still the same.  🤔
Mustrum
Fixes: 81
@stevenwhit  did you actually report a fault, or just post on here?
stevenwhit
Yes, via Text reporting.  This was the last text I received in response to the report from them Wednesday 13th:
Fixes: 479
@stevenwhit
Log in to your Plusnet account and see if a ticket has been raised for this fault. If so it might give more information.
willcutforth
Fixes: 113
@stevenwhit here is the ticket https://www.plus.net/wizard/?p=view_question&id=236876399
 Will Cutforth
