Moving Master Socket
- Moving Master Socket
09-07-2013 6:11 AM
Hi
Apologies if this is the wrong forum section. Is it possible to have my BT master socket moved? Can you pay BT or does it have to be your phone supplier?
Or can you do it yourself if u don't tell anyone
Chris.
Chris.
Message 1 of 2
(530 Views)
1 REPLY 1
Re: Moving Master Socket
09-07-2013 7:54 AM
You could try phoning the number mentioned in this thread - http://forums.moneysavingexpert.com/showthread.php?t=3043196&page=1
and see if you get the same official answer !
Message 2 of 2
(273 Views)
