Modem random drop-outs
Fixes: 586
Re: Modem random drop-outs
I may have a Hub 2 somewhere, though I've been with PN for over 10 years
The Hub 2 has only been supplied for a couple of years so unless you've had a PN router since then , it will likely be a Hub 1 which can't be set to bridge mode.
NB no need to fully quote the previous post, in fact doing so will incur the wrath of the mods😀
mdubash
Thanks for your help - glad it got fixed is the main thing. The modem will, I hope just be a stop-gap until full fibre arrives sometime Soon(TM).
PS: Mods don't want threaded discussions? Weird.
Fixes: 586
Its just that quoting the whole immediately preceding post takes up unneccesary space
from the forum rules https://community.plus.net/t5/Community-Announcements/Forum-Rules/td-p/1167432
General Forum Etiquette
  • Quotes are a useful way of showing which post/partial post you are replying to.
  • You should not quote a full post unless; (i)It’s not the post immediately prior to your reply or (ii)Your post is the first on a new page
