Moan moan adsl2+ is slow
- Moan moan adsl2+ is slow
17-06-2009 11:39 AM
4.0 Mbps - Checked on 2009-04-09 18:03:02 Current line speed: 2500.
ADSL Link Downstream Upstream
Connection Speed 3068 kbps 444 kbps
Line Attenuation 54.0 db 31.2 db
Noise Margin 10.4 db 17.4 db
are there any answers from plusnet about this problem?
Re: Moan moan adsl2+ is slow
17-06-2009 11:42 AM
It looks as though there might have been an increase in your noise margin - possibly from the poor weather we had at the start of this week.
I'd personally suggest checking that your wiring is as good as it can be (router connecting into your test socket via a filter is best) and waiting a few days for the DLM to recalculate your SNR.
17-06-2009 12:03 PM
17-06-2009 12:25 PM
Can you tell us about your wiring setup? It seems that ADSL2+ is more susceptible to non-optimal wiring, hence my previous comment about using the test socket.
17-06-2009 12:30 PM
17-06-2009 1:35 PM
17-06-2009 1:50 PM
Connection Speed 3070 kbps 444 kbps
Line Attenuation 54.5 db 31.3 db
Noise Margin 6.9 db 18.5 db
17-06-2009 2:27 PM
my line is not the best qaulity pieace of copper but on adsl2 on 50db atten the highest sync ive had yet is 4544 at 9db noise margin.
due to thunder storms its now sat at 15db noise margin with a sync of 3715
as your sync seems to be one of those fixed ones i had not so long ago i dont thing any amount of test socket ect is going to make it move.
how long have you been at 3068-3070 sync for now?
longest ive had fixed sync's on adsl2 for was between 1-2 weeks and had it happen on 2 values of sync 3070 and top end it was 4544
17-06-2009 2:37 PM
Quote from: ASBO if your atten is reported right then it seems to me you line is only slightly under performing
this is roughly what the stats were before the trial:
down...5376kbps
up.....448
line attenuation down...50db
line attenuation up ...31.5db
noise margin down... 7.4db
noise margin up....23db
ive been at this 3070 sync speed from a few days into the trial which would be 2 months roughly, it seems very strange that adsl2+ is marketed as the new new with bells when infact it seems to be going in the wrong direction. ive ordered a new set of phones so tommorow there will only be the router and 1 phone plugged into the filter, we need new phones anyways so good excuse to tidy up the wireing finally - im hoping that may help.
17-06-2009 2:46 PM
James: Has he been provisioned correctly?
17-06-2009 2:58 PM
there is one trialist that asked for the upload to be capped thinking it gave them better downspeed wonder if it was the OP
17-06-2009 2:59 PM
Quote from: jelv I'm wondering why your upload is so slow!
Capped upload won't have any bearing on download speed being slow.
17-06-2009 3:38 PM
Quote from: ASBO gd point jelv i over looked that
nah wasnt me
17-06-2009 3:44 PM
Whilst I don't expect this to improve your download speeds, there's an off-chance that it might force your line to retrain and get better speeds.
We'll see tomorrow though.
17-06-2009 6:03 PM
Quote from: Jameseh
True, but one of the benefits of ADSL2+, even if there is no improvement in download speed, is the increased upload speed and he hasn't even got that (probably due to Plusnet incorrectly ordering the upgrade).
