Migrated away from plusnet but services still running
400ixl
I migrated away from Plusnet last Friday (Openreach to CityFibre).
It was an early migration away so expecting to pay the early termination.
I got the email from Plusnet confirming my new ISP has told them I am leaving and confirming the date.
A week on from having the new service from that date and broadband and phone are still working and no final bill.
How long does this usually take?
Have tried calling but get a your number is not recognised for an account and then end up in a queue for an hour.
Do I need to sit in a long queue or am I concerned about something I shouldn't be and will see the final bill soon?
11 REPLIES 11
Fixes: 357
Re: Migrated away from plusnet but services still running
@400ixl So, you are saying you moved to new ISP (FTTC to FTTP, presumably), and your FTTC service is still live? That does not make sense - in fact it is impossible.
400ixl
Perfectly possible, as I said, I have moved from Openreach infrastructure FTTC to CityFibre FTTP so the old infrastructure is still in place as Citryfibre do not re-use Openreach equipment. Although forgot to mention FTTC to FTTP
Switch was to Aquiss from Plusnet and Aquiss on Cityfibre went live last Friday.
Fixes: 105
@jab1
It's entirely possible if the OP is on CityFibre's own network.
I'm on the OR FTTP network. I could get a second line through CityFibre because they don't touch the OR network.
I would advise the OP to contact PN to see what's going on.
Fixes: 357
Using your own router, I assume?
Mustrum
Fixes: 81
@400ixl   You can normally expect to get your final bill around 21 days after your service moves.
As for cutting off your old service, you may get dial tone for a while longer, and your internet should stop soon, but as you may already have paid for it it will be linked to your notice period.
Fixes: 357
@bmc wrote:
@jab1
I appreciate that - but I am still confused. BTW, I've been around long enough to know the technicalities invovled.
400ixl
Yes, have always used my own router. Dug the Plusnet hub out to be able to run them in parallel for the swap over day and have left it connected. Just tested it and the phone line and both are still active.
Fixes: 105
@jab1
Other possibility is PN have simply forgotten to hit the OFF switch.
Fixes: 357
@400ixl I suggest you call PN - something appears to have gone slightly wrong.
400ixl
@jab1 I have Plusnet on FTTC on Openreach infradstructure. CityFibre recently completed their deployment to our street. I ordered FTTP via Aquiss and the one touch migration.
Once ordered, got the email from Plusnet stating they have been told I am am leaving and I will get a final bill when I switch.
CityFibre cam on the day and installed their FTTP Fibre alongside the openreach Plusnet FTTC with my router on Aquiss and the Smarthub on Plusnet
This left me with both running side by side (Changed the wifi names to be different obviously)
Just tested both the Plusnet broadband and phone line and they are still active. Had expected them to have been killed by now.
Billing period is to the 26th so maybe it will happen tomorrow.
Luckily I have a credit from poor service which will pay for the early termination costs.
Thanks for the responses everyone btw.
Have pinged them on Twitter, it was saying an hour on the phone line so will try again another time.
Fixes: 357
I have a suspicion the OTS has not picked this up as you were not switching the same service to Aquiss. As I suggested previously, call Plusnet.
