Master socket needs upgrading
cobb1es
Hi all,
My connection is very intermittent. I have a very old master socket which has seen better days.
How do I go about getting a new one? Does Plusnet contact BT on my behalf? Is there a fee?
7 REPLIES 7
Fixes: 387
Re: Master socket needs upgrading
@cobb1es Are you sure it is the socket at fault? Which product are you on, and which router are you using?
What are the symptoms of your issue?
Fixes: 118
@cobb1es
Is Full Fibre available to you?
Fixes: 118
@cobb1es
Have you checked to see if there's a line fault?
https://www.plus.net/help/broadband/fix-broadband-problems/
If one is identified you could get an engineer out who "might" tidy up your connection.
Edit : Following @PhilipHeyes post this shows various BT Master Sockets
https://www.bt.com/help/broadband/getting-set-up/home-networks/a-wired-home-network/what-type-of-pho...
PhilipHeyes
Champion
Fixes: 20
The photos show a Junction Box.
This is a Master Socket
Fixes: 387
@cobb1es Who set this up? As @PhilipHeyes says, that is not a master socket, and whoever set it up was, to say the least, very unprofessional.
Personally, I would report a fault as suggested above, and talk nice to the engineer if/when they come, to get the connection regularised.
mystreet1
Seasoned Pro
Fixes: 7
@cobb1es, the images you have posted shows the external 'dropwire' being crimped to the internal cable. Second image is a BT connection box to do the same function. As suggested above, run a fault test.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
njay
Looks to me like the 1st photo is showing what is inside the internal junction box that has been removed in the 2nd photo.
I thought these had 4 jelly crimps rather than 2 shown?
