MTU help please
- Re: MTU help please
- « Previous
- Next »
Re: MTU help please
20-04-2013 5:34 AM
Richard you're on the right page I think, but not logged in. Click the login link on the top right and the buttons should appear...
(This screenshot is from an older router but the layout is very similar - ignore the red annotations)
Message 31 of 37
(488 Views)
Re: MTU help please
21-04-2013 10:13 AM
APJAshley1 - thanks.
I have logged in to the Belkin router and found the front page stays the same - no connect button.
On the before and after ADSL speed snaps, I wasn't clear - sorry. I sent two snaps: the earlier from a slow period and the later from a post-reboot fast period. They are identical, if I recall. I'll send this but instantly check on the snaps I sent (I know, I'm thick: when I am in reply-mode I can't see the attachments of earlier posts...)
Message 32 of 37
(488 Views)
Re: MTU help please
21-04-2013 10:16 AM
... and back again after a minute or so checking the supposed two snaps I sent from 190413. I actually only sent one snap, but the story's the same. The ADSL numbers did not change as between a mid-crawl snap and a post-reboot good performance snap.
Message 33 of 37
(488 Views)
Re: MTU help please
21-04-2013 11:37 AM
Is this of interest? In a brief but standard go-to-crawl, the Belkin settings page has reported the date as being something or other in 1970. (The ADSL speed settings have remained constant throughout.) This date peculiarity has happened after previous crawl-reboot episodes and has sorted itself out over a few or maybe several hours.
Message 34 of 37
(488 Views)
Re: MTU help please
21-04-2013 1:02 PM
Although your ADSL line stats are less than ideal, I'm not sure that's the main problem. It sounds like a buggy router really. There's a firmware update 1.00.52 dated 02/02/11 on the belkin website.
Message 35 of 37
(488 Views)
Re: MTU help please
21-04-2013 10:01 PM
In view of the fact that the ADSL stats are not changing when things slow to a crawl, I'm inclined to agree with ejs. Check your current firmware and if needed upgrade to see if the problem goes away. If not, do you have another modem/router or can you borrow one to try?
Message 36 of 37
(488 Views)
Re: MTU help please
26-04-2013 11:23 PM
What's the latest then RDN? Haven't broken your camera I hope!
Message 37 of 37
(488 Views)
- « Previous
- Next »
