Low Throughput, High sync speed, Nil Output Power
- Low Throughput, High sync speed, Nil Output Power
Re: Low Throughput, High sync speed, Nil Output Power
20-07-2012 10:04 AM
20-07-2012 10:21 AM
Quote from: Oldjim Staff need to check if there is a mismatch between the BT IP profiles - there are two systems and they should be the same
Is this something that I should be asking for, how will i be able to get "staff need to check..............."
20-07-2012 10:22 AM
20-07-2012 12:08 PM
20-07-2012 2:40 PM
Why then, after concluding that it is a faulty line is it my problem to have to contact BT and ask them yet again to test the line and raise a fault ticket. As I do not obtain my BB from BT what incentive do they have to fix my line so that I might receive BB in a reasonable condition.
As this is probably going to be an intermittent fault I might have to go over this long drawn out process for years to come. It might be seen as 'passing the buck'.
If anyone can enlighten me how a BB signal fails when a telephone line is OK using the same pair of copper wires would be welcomed.
20-07-2012 5:13 PM
Your netstat is showing something is using your connection, and the tracert is showing the first hop timing is high if connected by ethernet cable.
Usually the response time is 1ms or less between a computer and the router, but yours nearly 100ms suggesting your on wifi.
I dont recognise or know what is running on your pc, but it looks like it's searching through your ports on your internet connection. can you find out what they are by doing netsat /b to tell you what program is doing it just for peace of mind that it's not a trojan or something.
Other then that, all i can suggest is try your laptop on someone elses connection and do a speedtest to eliminate it from the problem.
20-07-2012 7:22 PM
20-07-2012 7:32 PM
Quote from: Swingletree Plusnet have concluded that yet again there is a copper line fault. I have no trouble with telephony. ............................. As I do not obtain my BB from BT what incentive do they have to fix my line so that I might receive BB in a reasonable condition.
If Plusnet have told you that you have a line fault, then you should not ignore it. I don't suppose the ticket says what type of fault it is? But in any event you could have several different faults that would not necessarily show immediately as a telephony problem, but could never the less affect the Broadband.
When reporting a phone line problem you NEVER mention the broadband, otherwise you will get the run around.
Just ring BT faults and make something up, just say the phone didn't ring properly very recently and you were talking with soneone and they said to ring up and get BT to run a line test. Just ask them to run a line test. Simples.
If the test comes back clear then obviously its intermittent and those are always a problem. So then get back to Plusnet and ask them exactly what the line fault was (if it's not on the ticket). And post that information here.
20-07-2012 8:12 PM
21-07-2012 9:34 AM
It says the fault is with your equipement at your home (CA = Customer Aparatus), and it advises you at the bottom (EU = End User) to re check all your equipement and internal wiring.
BT telephone engineers dont check your broadband equipement and internal wiring as far as I'm aware, so calling for a BT telephone engineer to check the line is a waste of time and money.
Either you have to do some Sherlock Holmes work at home, or plusnet can call out a broadband engineer to check your equipement in your house which they will most likely charge you for.
21-07-2012 9:41 AM
dick:quote
21-07-2012 9:58 AM
That is NOT the correct interpretation of the test result. It means further checks need to be carried out to check it isn't CA, and as the OP has stated that was done. That type of fault can occur on a line as a result of corrosion at some joints or as a result of a faulty NTE5 for example.
Furthermore that is a clear fault that OpenReach are responsible to fix, by reporting the issue to the Line Rental Provider.
@Swingletree
As I previously stated, report it to BT Retail, if necessary insist on a further line test, but that shouldn't really be necessary as the test results above should be recorded on BT's systems.
Edit: That type of fault can also cause "ring-trip" on incoming calls, meaning a caller may hear a brief ring before it's tripped to the answered state and then they hear nothing or just noise. I don't suggest you try to create an incoming call until you've reported the fault as sometimes Ringing current can temporarily clean a corroded joint, and the problem will return sometime later.
21-07-2012 10:17 AM
dick:quote
21-07-2012 10:18 AM
Swingletree did not post earlier he had removed the faceplate and carried out further tests until after my post.
A standard BT telephone engineer will not check for the copper line faults, his only criteria is to check the functionality of the voice line. Swingletree has already stated the telephone is working fine and a BT telephone engineer has already been out and found no fault with the voice/telephone part which a BT telephone engineer would be concerned with.
Swingletree needs a Broadband/SFI engineer visit which would have to be requested through plusnet.
21-07-2012 10:20 AM
dick:quote
