Low Broadband speeds
- Re: Low Broadband speeds
- « Previous
- 1
- 2
- Next »
11-10-2022 12:20 PM
Weird - they were retired a long time ago, and the double sockets are OK, so long as they are installed correctly - I've had one for couple of years with no issue.
Message 16 of 18
(709 Views)
11-10-2022 12:25 PM - edited 11-10-2022 12:26 PM
Mine kept breaking contact until I put some sticky tape on 2 sides.
Message 17 of 18
(707 Views)
11-10-2022 12:28 PM
Depens how well they are installed to a flat surface - if they are screwed too tight on an uneven wall, then yes, I understand they can be a problem.
Message 18 of 18
(704 Views)
- « Previous
- 1
- 2
- Next »
