Lost about 1 MB/s down again
- Lost about 1 MB/s down again
21-10-2022 10:31 AM
Back to 3.5MB/s or so. Last time this mentioned a handy plusnet person chimed in and got me back up to my max of 4.5MB/s.
Could someone look into this for me? Thanks ![]()
Re: Lost about 1 MB/s down again
23-10-2022 3:05 PM
Hey @tankabbott,
Thanks for reaching out to us and I'm sorry to hear that you're having issues with the speeds at the moment. I've had a look into this and the speeds I'm seeing are completely different from the ones you're reporting - do you have more than one account with us?
23-10-2022 3:21 PM - edited 23-10-2022 3:22 PM
Hi AJ, nah same one
Here's a post from my last thread about this (helped by Gandalf [staff[)
I've done a bit of digging and from what I can see your router's sync speed is 'banded' to a max of 35mbps by the dynamic line management (DLM) software at the cabinet. I've arranged for the settings to be reset, which should happen within the next 3 working days and hopefully increase your speed to where they were before.
I was able to get 4.5MB again after his help, which I know is my usual max as I download a lot of STEAM ![]()
23-10-2022 3:42 PM
Thanks for confirming that @tankabbott. Since this went through, have you noticed any other issues with the line? For example, shortly following the change we made, did the connection drop out at all?
23-10-2022 3:42 PM
No drop outs touch wood, just the lack of max speed again ![]()
23-10-2022 4:04 PM
No worries, just wanted to make sure there aren't any underlying issues we need to worry about. I've requested the same changes be made and I've logged a support ticket here on your account concerning this. If you run into any further problems then just let me know and I'll get back to you as soon as possible ![]()
