Losing connection random
dp3435
Hello,
I'd appreciate some help with my plus one router.
I have a wired connection to a PC and several wireless devices.
At random times the blue light goes off and I get the orange one, sometimes with the 'b' under it.  This can be for a minute before it becomes blue again and other times for longer.  What's strange is that it can be on and off in quick succession and then fine again for days.
It seems to happen more during the day I think, so I have put up with it.  It did become a problem during lockdown.
I can't seem to think of a reason / pattern for why it would do it - so I would suggest it's a router fault?
I'm not an expert with tech (7/10), but I am good at following instructions - so any advice would be great!  I've tried the generic FAQ ones.  I saw a similar post on here that had the same issue, which was resolved with a new router.
Cheers, Dave.
8 REPLIES 8
Fixes: 387
Re: Losing connection random
@dp3435 The symptoms you describe could be down to any number of reasons, but if you follow the below, Community members/Help Team staff will probably be able to resolve the problem.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
Fixes: 1,662
Hi Dave, I'm really sorry to see you're having connection issues.
I've just tested your line and the tests are picking up on a line fault, so I'd like to arrange an Openreach engineer with you to take a closer look. Could drop me a reply onto the ticket I've created Here with when you'll be available for a visit?
If you can post back once you've responded, I can make sure we book the engineer as soon as we can.
Cheers
dp3435
Thank you for the quick responses.
I have added my availability to the ticket.
I'm glad a fault has been detected - so hopefully we can get it sorted.
Cheers - Dave.
Fixes: 1,662
Awesome. Cheers Dave.
I've just added a reply to the ticket 222814913 now.
Feel free to prod me again once you've responded.
dp3435
Thank you - done Smiley
Fixes: 1,662
Cheers, I can see we've booked the engineer and updated the ticket 222814913 with the appointment details.
Let me know how it goes Smiley
dp3435
Been meaning to post for a while - but I wanted to say thank you to the team for quickly organising the support and I have not had any issues since.
Thanks again!
adamwalker
Fixes: 223
Marvelous! Thanks a lot for letting us know, that's great to see Smiley
 Adam Walker
