Line speed reset
g0uex
Line speed reset
Could someone reset my line speed please, the modem was power cycled a few times a couple of weeks ago and it dropped my connection speed from around 75mbit to around 60mbit. I have waited a while to see if it would retrain itself.
6 REPLIES 6
willcutforth
Fixes: 113
Re: Line speed reset
Done for you now @g0uex
 Will Cutforth
g0uex
Thanks. There is no change at my end yet, does it take time to propagate or do I have to force a reconnection or anything?
willcutforth
Fixes: 113
I would force a reconnection just so that it gives it a reboot.
 Will Cutforth
g0uex
Quick reboot sorted thanks.
willcutforth
Fixes: 113
Awesome. If you need anything else just drop me a message.
 Will Cutforth
g0uex
Will do, thanks again for your time.
