Line speed is not sync speed
- Line speed is not sync speed
30-10-2009 10:16 AM
Just when you thought you'd understood something...
Can someone clarify the difference between sync speed and the "current line speed" as reported by the User Portal?
My "current line speed" is shown on the portal as "6000". This seems consistent with past speed test results of around 5500 (kbps). However, my router reports "downstream data rate" currently at 7360. The portal page says the 6000 figure "is based on your sync speed", but doesn't say how.
The FAQ pages talk about "Sync Speed (Line Rate)" and "Throughput Speed (Data Rate)", which I would read as the 7360 and 5500 figures, but the tables imply the difference should be less. I can see no definition of "current line speed".
Message 1 of 3
(778 Views)
2 REPLIES 2
Re: Line speed is not sync speed
30-10-2009 10:20 AM
The synch speed is the speed with which your router connects to the internet.
The current line speed is a copy of the IPprofile which is set be the automatic systems at the exchange.
The IPprofile is banded and depends on the lowest sync speed in the previous 3 days (approx)
Have a read here
http://www.kitz.co.uk/adsl/IPprofile.htm
Have a read here
Message 2 of 3
(345 Views)
30-10-2009 12:03 PM
OK, thanks. I suspected it might be the Profile, but the BT Speedtester no longer works on my line so I couldn't check. The kitz calculator explains it perfectly.
Message 3 of 3
(345 Views)
