why has my line speed been trashed down again?
bluewhale
now down to 2500 rather than the 10000 or so it's been for weeks?
maybe i have a rain issue on the line somewhere?
is this real or a glitch and can i get bt to look at if it is real?
cheers
pete
bluewhale
Re: why has my line speed been trashed down again?
anyone out there to give me some help
i'm back to pre 8meg speeds :-(
james?
Cry
ComplexP
If your speed has dropped from 10MBits to 2.5MBits it could indicate a problem. Do you still get a sync rate of 10000? If your line glitched to 2500 for a few hours it could have reset your throughput profile in which case it could take several days of stable connection for your speed to pick up again.
scootie
if you can post your line stats and what your BT an PN profiles are, we can start to get a picture of your line
bluewhale
sadly can't get the line stats on the firmware i have :-(
anyway it's now creaping back up
really wish is wasn't so trigger happy
bluewhale
this is what the bt speed test cam up with, sadly my profile is locking me down still... :-(
Download speedachieved during the test was - 2602 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :9205 Kbps(DOWN-STREAM), 1181 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 7.57:25.79:66.64 (SBE:NBETongueBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
scootie
whats all that on the test? am on best effort add on and dont see none of that
Hi bluewhale,
It looks like your connection might be dropping intermittently, have you noticed any disconnections while using the service at all? I'd recommend testing with the router in the master socket and all your other phones unplugged from the line, if it's still dropping then you should raise us a fault at http://faults.plus.net so we can investigate it for you.
bluewhale
yes i can see the adsl being dropped, but the phone has been perfect
and nothing has changed in my house and for that matter with the weather outside
hate having to raise a ticket as it'll be a run around for days :-(
ho hum.....
bluewhale
well ticket raised and no response :-(
also my syncing still going around in circles with the profiles following around a day behind...aaarggggh
Fixes: 10
I can almost guarantee that the first thing the response on the ticket will ask for is for you to plug the router in to the test socket with no other equipment connected as Matt recommended. Have you done that?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
James
Hi Bluewhale,
I'll reply to your ticket in a second, but it's really important that you do try to test from the test socket as this will eliminate your internal wiring being the cause of the problem.
James
Bluewhale,
I've replied to your ticket at some length.
bluewhale
is there any point to that as the router is at the max of the band and ok, the disconnects will be me getting impatient :-)
the annoying thing is that plusnet profile is at 3500 even though i'm connecting at 6000 and so would imagine bt reflects that
takes days ( it seems ) for plusnet to reflect new rate...so no chance of speed getting increased ( without me getting impatient :-))
will the router connect at speeds out of the band? can we force the band higher?
it isn't practical to have the router into the socket for long as would have no phone then?
cheers
pete
James
I'll answer your questions when you've answered mine Smiley
Are you in the test socket yet?
Your profile hasn't updated because you've had so many disconnections.
