Line speed dropped from 2.5mb to 512k is my cn21 activated?
- Line speed dropped from 2.5mb to 512k is my cn21 a...
Re: Line speed dropped from 2.5mb to 512k is my cn21 activated?
25-09-2009 9:33 AM
I can't even test his circuit on the standard ADSL service as his ADSL asset has been ceased (obviously there's now a new one on ADSL2).
Either way - I can't raise a speed related fault in the first ten days.
25-09-2009 9:38 AM
It may be worth explicitly setting the router to ADSL2+ (ITU-T G.922.5) or at least ensuring "multimode" has been set?
25-09-2009 9:40 AM
25-09-2009 9:43 AM
25-09-2009 9:44 AM
25-09-2009 9:46 AM
Device:
Name TG585 v7
Serial # 0904UFCT6
Device Configuration:
Region UK
Provider Plusnet
Service Other
Description Plusnet configuration for other customers.
Routed Internet Connection:
VPI/VCI 0.38
Connection Type PPPoA (UK Default)
User Name
Password ********
Router Addressing:
LAN Addressing Scheme Private_IP-(with_NAT)
IP address of your Thomson Gateway 192.168.1.254
Network Address
Subnet Mask
Address Management:
Enable DHCP enabled
25-09-2009 9:54 AM
I think the Thomson router is set to multimode by default IIRC.
I'm not familiar with that router but hopefully someone on here is and will be able to point you in the right direction.
If it is set to multimode you may just have to wait the ten days and then raise a fault if nothing's changed
25-09-2009 10:02 AM
25-09-2009 12:25 PM
Link Information
Uptime: 0 days, 3:04:48
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 288 / 576
25-09-2009 1:26 PM
I'd expect this to pick up over the next 3 days - it's just the initial training appears to have hit a poor sync event and should hopefully pick up soon.
25-09-2009 1:34 PM
25-09-2009 4:28 PM
25-09-2009 4:45 PM
25-09-2009 5:45 PM
Uptime: 0 days, 8:24:54
Output Power (Up/Down) [dBm]: 11.0 / 14.5
Line Attenuation (Up/Down) [dB]: 28.5 / 49.0
SN Margin (Up/Down) [dB]: 29.0 / 28.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 12
HEC Errors (Up/Down): 0 / 1
Well mine is the same as that is that good or bad?
26-09-2009 9:28 AM
