Line speed dropped from 2.5mb to 512k is my cn21 activated?
duffy
Hi All I think my order has been completed at it was return to the BOT team, however i have since done a line test hand the download speed has dropped from 2.5mbs to 512k can anyone advise me on this please case id is 29460055
duffy
Re: Line speed dropped from 2.5mb to 512k is my cn21 activated?
Today 23:30 531 kbps (66.4kB/s) 218 kbps (27.3kB/s) Share
Today 23:21 526 kbps (65.8kB/s) 125 kbps (15.6kB/s) Share
Today 23:14 542 kbps (67.8kB/s) 218 kbps (27.3kB/s) Share
Tuesday 23:12 2338 kbps (292kB/s) 335 kbps (41.9kB/s) Share
Aug 10, 19:11 2660 kbps (333kB/s) 321 kbps (40.1kB/s) Share
Jul 23, 20:57 2797 kbps (350kB/s) 333 kbps (41.6kB/s) Share
Jul 21, 23:15 2778 kbps (347kB/s) 335 kbps (41.9kB/s) Share
Thomson Gateway  Information
Product Name: TG585 v7
Software Release: 7.4.4.7
duffy
00:00:41 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 576 kbit/s, upstream: 288 kbit/s; output Power Down: 14.5 dBm, Up: 10.5 dBm; line Attenuation Down: 49.0 dB, Up: 28.5 dB; snr Margin Down: 30.5 dB, Up: 29.0 dB)
paulby
G.992.1 is standard ADSL not ADSL2+ (which is G.992.5).
It also looks from your sync speed that you've been put on a fixed 512k rather than ADSL2+
duffy
so how do i get this fixed any ideas, as this is driving me crazy as wfh today!
paulby
James should be along soon so hopefully he'll pick this up for you, otherwise you'd need to raise a ticket or phone support.
duffy
Ok will wait for james then thanks
James
Duffy,
You are on ADSL2+, but it looks, er, a bit on the slow side.
Can you try rebooting your router and see if it makes any difference at all?
duffy
Hi I did a reboot via the web page last night, do you want me to doa hard reboot?
James
It won't hurt at all to try.
It sounds like a dodgy resync event which might have resulted in a banded profile.  If you still sync at the same speed after a reboot - leave it for 3 days and the sync speed should spring back to life.
duffy
00:00:45 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 576 kbit/s, upstream: 288 kbit/s; output Power Down: 14.5 dBm, Up: 11.0 dBm; line Attenuation Down: 49.0 dB, Up: 28.5 dB; snr Margin Down: 30.5 dB, Up: 29.0 dB)
duffy
still the same Sad
James
Ok - In which case your need to wait a bit I'm afraid.
It's part of the initial training period, I'd suspect.
duffy
but everything else checks out then, mtu, profile  etc, as the other chap wrote i was on the wrong standard or somethng
paulby
@Jameseh
The router stats suggest that the router is connecting using standard DSL (ITU-T G992.1 is standard ADSL) and the sync rates are those of a fixed 512k service (576down 288up).  Has his equipment negotiated a standard ADSL connection with the exchange or is there something else up?
