Line reset please
Biz55
Line reset please
Ever since recent Openreach repair to our broken landline my broadband speed has decreased from about 10mbps to 7mbps.
I have read that others have resolved this with a line reset. So can I please get a reset ?
20 REPLIES 20
ClaudiaG23
Fixes: 25
Re: Line reset please
Hi @Biz55 I'm struggling to find a recently fault on your account we have for you. When was this fault please?
 Claudia Garner
Biz55
The problem is happening all the time.
I used to get about 10mbps. Ever since Openreach repaired my land line recently, I am down to about 7mbps. Would it be possible to try improving this with a reset ?
Fixes: 387
@Biz55 As Claudia has asked - when (roughly) did OR 'repair' your line?
@Biz55
A line reset is the only solution if your broadband connection has become stuck after becoming 'banded' or had a 'capped profile' applied,  but won't improve a connection that is performing badly due to ongoing interference, sub-optimal phone socket wiring, or an external line problem.
Perhaps @jab1 can walk you through (with his useful scripts) how to post here your router's DSL stats, so we can advise why you are seeing slower speeds than previously.
Fixes: 387
Happy to oblige, @Anonymous
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Biz55
Thanks.
Openreach repaired the landline on Tuesday 9th February.
Fixes: 387
Last year then?
Biz55
Woops.
January
Biz55
Thanks very much John. Here are some screenshots. ( my router is Tp_Link not BT Hub)
Fixes: 387
@Biz55 It appears from that that you are suffering from xDSL failures - unless you intentionally have disconnected - note the 'uptime'.
Your router is also reporting an 'max achievable' which is not supported by the information on the BTW page.
Biz55
I did switch the router off and on a few times yesterday when Plusnet had an outage.
Fixes: 387
OK - that was unfortunate, and not something I would recommend as a standard practise. Does your router have a readable error log?
@Biz55
TP-Link xDSL router logs are usually here Click Advanced > System Tools > System Log page.
It should be possible to save the log as a a text file which can be attached to a post
HTH
Biz55
Log Attached thanks
