Line reset - in training ? - is this normal behaviour
- Re: Line reset - in training ? - is this normal be...
Re: Line reset - in training ? - is this normal behaviour
26-02-2016 1:42 PM
Current line speed is sitting at 2.5 having been at 3 for a short while.
Couple of things though
1 I can't get more than about 100kbps download speed when browsing the web or downloading files - not sure why this should be as previously when I had some good connections rates I was getting around 250-300 ?
2 Have been running Routerstats during the time I have had issues and it has been invaluable helping me track down the problems and, hopefully, reach a solution BUT for some reason since the last rest (maybe a co-incidence ?) RS will just stop showing any data. It is not the router doing anything that I know of - it just drops speed, SNR etc down to 0 and site there quite happily plotting !! A quick click on the buttons and away she goes again. Can't seem to see what might be causing it as the periods it runs are quite variable. Anyone else had this sort of thing with RS ?
26-02-2016 7:19 PM
That's a bit disappointing if your Current Line speed is 2.5 because it sounds like a connection drop at some point. Check the BT IP Profile again as well, they should always end up matching but as you probably know the Current Line Speed will lag behind a bit until the BT servers send the Delta Report and Plusnet's script do an update.
Not sure what is causing the download speed issue, but some types of download speed may be restricted a bit at peak times. Other than that, high error levels could cause that, meaning lots of data retransmission.
27-02-2016 10:21 AM
Quote from: dc8 1 I can't get more than about 100kbps download speed when browsing the web or downloading files - not sure why this should be as previously when I had some good connections rates I was getting around 250-300 ?
Are you sure that you are reading the units correctly? File down load tools frequently report speeds in Bytes / second (kBps) not Bits per second (kbps). 250-300kBps would not be too far out for a 2.5 to 3mbps connected service.
27-02-2016 12:41 PM
It was just a feeling initially that things were slow so I checked with the same tools that I have always had on the system - Networx and a download manager within Firefox itself.
Units shown on the Network graph are KB/s and these used to go well over 200 at one point. I also used to get over 120 on the Firefox download manager even when my initial problems started but this also ties in now with the figures from Networx showing around 80-100 !!
Took me 15 minutes+ last night to download a Java update (~55Meg) and I am pretty sure that with the speeds I am supposed to be getting according to my IP profile that there is something still not right with things. Your figures of 250-300Kbps were what I was expecting to see with the new "improved" connection and which I did see when I was reset a while back and during times when my profile was still OK before it dropped as I was looking for the problems on the line initially.
Was hoping that things were all going to run smoothly now but seems that this is still a pipedream lol !!
27-02-2016 3:21 PM
Very confused now about what speed I should be expecting as current downloads are PAINFULLY slow and really not what I was expecting after all the other issues I have had recently.
Have had a rock steady connection now for over a day at 3808 as can be seen from the stats below. Now have interleaving turned on as the FRC count has started whereas before I was getting many CRC and ES counts.
Uptime: 1 day, 7:33:35
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.808
Data Transferred (Sent/Received) [MB/MB]: 336,17 / 913,78
Output Power (Up/Down) [dBm]: 12,1 / 19,3
Line Attenuation (Up/Down) [dB]: 31,5 / 56,0
SN Margin (Up/Down) [dB]: 18,0 / 5,8
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 18 / -
Loss of Signal (Local/Remote): 2 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 11.290 / -
FEC Errors (Up/Down): 83 / 2.473.208
CRC Errors (Up/Down): 7 / 256
HEC Errors (Up/Down): - / 256 / 1.525
27-02-2016 5:31 PM
27-02-2016 6:41 PM
28-02-2016 4:54 PM
28-02-2016 5:52 PM
Yep, frustratingly, still the same.
DSLstats shows a steady connection at 3808 and an up-time of 2 days 10 hours plus now so looks like things have settled down hopefully.
All I need now is to be able to download something without having to wait all day
Maybe there will be someone around on Monday who might be able to spray a bit of WD40 around and see if they can loosen the cogs up !!
29-02-2016 10:51 AM
Current line speed is showing as 3MB.
Thanks in advance,
29-02-2016 11:31 AM
29-02-2016 11:51 AM
29-02-2016 12:43 PM
There is history of CN20 BTw profiles being squiffy at times (another hidden BTw profile not being set properly).
@CRT,
Can someone review this please?
Edit: I'm reminded that sometimes after the PlusNET profile updates, the PPP session is not dropped to pick up the revised profile. You can fix this by logging into the router and manually dropping to PPP session and then reconnecting.
29-02-2016 12:47 PM
Its a 20CN connection AFAIK.
29-02-2016 1:00 PM
One thing that hasn't happened though is an increase in speed !! I Had one "blip" where it went to around 200 but generally sat around the 100 mark !!
