Line drops - line check request
PabloBruno
I have experienced a few service drops in my broadband over the last few days. Could somebody check my line please?
I have some really important online meetings later this week and next, so really want to sort any problems out soon if possible.
Many thanks in advance.
14 REPLIES 14
goldenfibre
Seasoned Pro
Fixes: 12
Re: Line drops - line check request
Check current line speed via plusnet member account and also run btwholesale performance test and click Additional Diagnostic here: https://speedtest.btwholesale.com/
PabloBruno
Thank you very much. This site does help with speed checks but does not test line integrity.
Could someone look at when/why these outages happened please?
James30
Fixes: 32
@PabloBruno  - It's been dropping a bit, have a look @ http://visualradius.plus.net/visualradius/generated/image16863350292535.png
Whilst testing your broadband I'm seeing a fault with your phone line externally so I've raised a fault on your account that you can track here @ https://www.plus.net/wizard/?p=view_question&id=234530487 and they've given a ERT of 13/06/23 but you will be updated once someone has been out and looked at it. Cheers
James - Plusnet Sheffield
PabloBruno
Many thanks James30 - I will be patient and await a response.
For some reason the fault is 'on hold' till Wednesday. Not sure why the delay is so long just because Plusnet need to contact BT - they are part of the same company after all.
Fixes: 336
@PabloBruno Openreach have a 2 working-day window for residential repairs as part of their Service Level Agreement, and although they are part of BT PLC, they are a separate entity.
PabloBruno
Hi - the drops are happening more and more. As I work from home my broadband is pretty business critical. It would be appreciated if this could be chased, and asked if BT didn't have to wait 2-3 days to respond.
Fixes: 336
@PabloBruno I am not PN staff, but  the 2 working-day SLA is what it is, and no-one can circumvent it.
PabloBruno
kay, but the drops are now every few minutes - if anyone can escalate this it would be much appreciated.
Fixes: 336
As above - the SLA is 2 days, and that is what you have. It cannot be 'escalated'.
Mustrum
Fixes: 81
No one is going to escalate this, it is Saturday night, tomorrow is Sunday Openreach are not due to investigate until Monday or Tuesday, you have chosen a budget broadband provider who are responding as per the SLA's they have agreed.
If broadband is critical to your work then surely you should be relying on your back up systems, or choosing an appropriate business grade supplier.
Just saying!
PabloBruno
You bring a wise and critical noise to the party.
Now go home.
PabloBruno
Earlier this morning I got a test from Openreach saying my fault had been fixed.
However, I am still experiencing drops and when the internet is working the speeds are very slow (16-21Mbps).
Please can someone look into this?
willcutforth
Fixes: 113
Hey there @PabloBruno ! Our suppliers are aware that the issue is not resolved yet and they have until midnight tonight before we can chase them. Our faults team will keep an eye on this for you.
 Will Cutforth
PabloBruno
Many thanks WIll - I'll be patient and wait for a response/resolution.
