Line drops at the same time each day.
- Re: Line drops at the same time each day.
09-10-2026 10:59 AM
I'm a new broadband customer (3 weeks) and the connection drops (goes to flashing orange light) at about 10am each day.....I power down the router and plug back in, the drop out lasts about 10 minutes. Other than this time of the day everything is fine.
Is this part of the setup and configuration process or a fault?
09-10-2026 11:06 AM - edited 09-10-2026 11:07 AM
@ghind I am assuming you are on FTTC (fibre to the cabinet) with a copper 'final mile'. This sounds like the DLM stabilising your connection, which will take very much longer if you continually drop the connection, and could leave you with a subpar speed.
Leave the connection up, and it should stabilise in 7-10 days.
Is the service SoGEA (part fibre) or FTTP?
@jab1 types faster.
09-10-2026 11:09 AM - edited 09-10-2026 11:11 AM
"Is this part of the setup and configuration process or a fault?"
It's clearly a fault. The question is: Is it caused by something in your home, or something external?
It sounds to me likely something is regularly causing electrical interference every day around 10am. Something switching on and off? Thermostat? Air conditioners? External electrical equipment? Trains?
Do you have access to an AM radio receiver? If so you could listen on medium wave at the expected time to hear if anything can be detected. That would be a start.
From above posts! Just thought: are you on full fibre or not? It could make a difference.
09-10-2026 11:11 AM
A new connection, @pvmb - see my post above.
09-10-2026 11:12 AM
...After "3 weeks"?
09-10-2026 11:13 AM
If the OP is dropping the connection daily - yes.
09-10-2026 11:20 AM - edited 09-10-2026 11:23 AM
...Do these things occur within normal working hours?
It's not quite the same but I remember when my ADSL 2+ line kept being re-banded it was in the wee small hours: around 5am.
Or perhaps like me, back in the day (or even now!), the OP switches his router off overnight? 😊
09-10-2026 11:28 AM
As I'm out for a while - I'll leave this - to @Townman (?)
09-10-2026 12:20 PM
Thanks. I'll just leave it to do its own thing for a while. Yes it's FTTC.
09-10-2026 1:10 PM
@ghind don't "leave it to do its own thing for a while" !
A line dropping out every day at 10am is NOT a known pattern of how DLM 'training' works. DLM training drop outs mostly occur in the first three days, and become less frequent for the following week, mostly occurring during the times of day when the measured SNR changes the most at dawn and dusk. In addition, DLM stabilisation re-syncs are momentary drops with near immediate recovery and do not necessitate the user rebooting the router, or persisting for ten minutes.
Can you post a screenshot of your router's web interface on the page that shows data rates, SNR, attenuation, etc ?
being careful to not show your Plusnet broadband login username.
Do you have ANYTHING on your home network or WiFi that uploads a lot of data to the internet, e.g. iPhones, cloud backups, media server, video doorbell, smart home devices that connect via the cloud, or any internet connected electronic device that starts being used around 10am ?
To give us an idea of how your internet connection is behaving,
run this test - https://www.waveform.com/tools/bufferbloat on a computer connected by an ethernet cable (not WiFi)
when the test completes, scroll down to where it says "Share Your Results:"
press the [Copy] button, and then paste that URL back in your reply here.
09-10-2026 1:24 PM
It seems there's a consensus on tech forums that 612khz is the best frequency for REIN detection.
Zen SOGEA 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
09-10-2026 2:12 PM
09-10-2026 4:59 PM
Thanks for that waveform data. A screenshot of your Technical Log - Information page would be helpful - assuming you are using the HUB2.
