Line Test Request
superuser
Line Test Request
Is it possible please to run a line test
Some drop outs recently and I know there has been some tree cutting around a line recently
25 REPLIES 25
Re: Line Test Request
@superuser
I would suggest using the following link to check your line https://www.plus.net/help/report-a-problem/
superuser
I have a new issue with this
Used the speed test thing, rebooted the router
Download is at 24 meg - It's usually 70+
I also texted the BOT, not very helpful
So can a fault be seen or raised?
Fixes: 387
What did the bot say?
superuser
It said go to the speedtest. I did
Then it said it would reset the connection, but then replied it could not, so recommended powering off the router and trying again
I did and the speed is the same
It said I could get a call back but I just came here, because a call back is usually just a waste of time for people that are basically dumb as dumb
We had some [-Censored-] weather here late weekend - it may be related
But I'd like an engineer to check it
Fixes: 387
I would have taken the call-back and requested an engineer - you are going to need one if they cannot do a reset automatically.
@superuser
are you using your own or a plusnet supplied hub?
I believe for a remote line reset a plusnet hub is required, a non plusnet supplied device is not managed by the CWMP/TR069 system.
superuser
@Dan_the_Van wrote:
@superuser
No
It's a Archer VR2100
superuser
OK
Well in the past I mention a problem here and it was the best way to get things done
Perhaps that has changed
@superuser
I would suggest either phoning or try the fault bot again with a request for a call back.
Has to be tomorrow.
Be handy to see DSL connections stats page
superuser
  Upstream Downstream
Current Rate (kbps) 14998 27398
Max Rate (kbps) 19054 112757
SNR Margin (dB) 6.9 28.2
Line Attenuation (dB) 2.8 10.6
Errors (pkts) 0 0
Fixes: 387
@superuser OUCH! at that d/s SNR. I suspect a line fault.
ADDED: Is the FTTC box in your garden?
superuser
In my garden, well maybe that's some Openreach junction box?
So I still need to report this fault with the call back?
You seem to know it is there but can't actually raise anything on it to get it sorted?
Fixes: 387
I only asked how close to the cab you were, as your attenuation figures suggest you are extremely close to it, which may in part explain your D/L SNR figure.
Yes, if you want the fault rectifying, you will need to report the fault - I can't because I am not PN staff, merely a forum contributor.
superuser
I am probably less than 50m away
I got the call back
They say no fault but there was an 'Incident' that has been resolved
They wanted me to do a factory reset on my Plusnet router, but I don't have a PN router
What difference that would make is beyond me
I have powered off and on again this AM and I still see this
Upstream Downstream
Max Rate (kbps) 18403 112049
SNR Margin (dB) 6.5 28.2
Line Attenuation (dB) 2.8 10.4
Errors (pkts) 0 0
