Line Speed - Router reports 7616Kbps Up, 448Kbps Down
- Re: Line Speed - Router reports 7616Kbps Up, 448Kb...
30-11-2008 1:04 AM
This isn't a complaint, so please don't treat it as such
My router is reporting a line speed of 7676Kbps upstream and 448Kbps downstream, however my actual download and upload speeds are the same as they've always been (240KBps up, 30-ish KBps down).
As far as I know, I'm on a 2Mbps line with PlusNet. Have I been upgraded Ninja-style?
Also, do I need to change anything to take advantage of this faster speed, providing my router isn't lying?
Cheers!
Last time I used this forum was when it was running phpBB. A lot has changed!
Cheers!
Message 1 of 8
(1,695 Views)
7 REPLIES 7
Re: Line Speed - Router reports 7616Kbps Up, 448Kbps Down
30-11-2008 3:01 AM
Hi
got one of my colleagues to update the line speed internally for you as I lack the permissions to do this (poor me )
so your speed should be sorted now. sorry it was a lil problem you account
can you do a speed test after rebooting your router please
Message 2 of 8
(632 Views)
30-11-2008 3:04 AM
Quote from: UberMensch Also, do I need to change anything to take advantage of this faster speed, providing my router isn't lying?
just a quick reboot
Quote from: UberMensch Last time I used this forum was when it was running phpBB. A lot has changed!
I wasn't working at here (i think) when forum was running on phpBB but I can imagine lol
Message 3 of 8
(632 Views)
30-11-2008 10:31 AM
Quote from: UberMensch my actual download and upload speeds are the same as they've always been (240Kbps up, 30-ish Kbps down).
Are you sure?
Not confusing bits (b) and Bytes (B)?
If those numbers ARE correct in bits-per-second you have a big problem
Message 4 of 8
(632 Views)
30-11-2008 11:21 AM
Quote from: HPsauce
Are you sure?
You're right there, after
I did indeed mean KBps
Message 5 of 8
(632 Views)
30-11-2008 11:25 AM
Run a BT Speed Test to confirm your IP profile.
If it's set a 2meg it may take 3 or 4 days to adjust.
Message 6 of 8
(632 Views)
30-11-2008 12:11 PM
Hi
I knew it was KB because your internal speed was set to 2000 now it has been change to match ur IP profile 6500
Message 7 of 8
(632 Views)
30-11-2008 12:16 PM
Just to add some relatively unexciting informatiom...
This forum changed to the be using the Community Site (and therefore SMF) roughly 18 months ago and your line will have been upgraded at some stage last year I would have thought
Message 8 of 8
(632 Views)
