Line Reset please?
- Line Reset please?
Re: Line Reset please?
26-05-2014 12:03 PM
26-05-2014 12:10 PM
In my case it made no difference and my attenuation is similar to yours
The fact that your default noise margin appears to be 12dB would indicate that there is room for improvement but it may be that you just have a noisy line
26-05-2014 1:29 PM
You might still be on ADSL(1) because the line configuration has not been changed. However due to the error rate it is possible that the DSLAM has determined that ADSL 2 modulation might not be viable.
Are you using the full version of RouterStats? If yes, take a look at the tones graphs. This will show you how many bits are present in each tone bucket and which tone buckets are usable. ADSL(1) does not use the higher numbered tones; long lines do not transmit the higher numbered tones well. See here - http://www.kitz.co.uk/adsl/adsl_technology.htm#tones - for more information if you are interested.
ADSL 2 can run with single bits in the tone buckets so it might be possible to squeeze a bit more out of the line.
Kevin
26-05-2014 2:46 PM
As an experiment I set my own line back to ADSL1 shortly before 7am this morning, my line not having been particularly stable lately. Now of course I can't be sure how it would have coped with today had I left it on ADSL2, but it's currently racking up CRC errors at an unfortunate rate on ADSL1. (No, I don't need any help fixing it, I just thought I should re-check ADSL1 vs. ADSL2 for myself.)
26-05-2014 3:05 PM
What's the tool please? Is it compatible with the tg582n?
Kevin
26-05-2014 3:26 PM
26-05-2014 7:16 PM
28-05-2014 2:31 PM
Thanks for your patience, I can see the fault is still ongoing following the engineer visit. After retesting your connection I believe we can resolve this remotely by changing how the exchange manages your connection.
We'll advise when we have completed all work, it could be up to 5 working days.
Does this mean a switch to ADSL2?
Thanks Mike
28-05-2014 2:35 PM
"Modify order placed to ADSL2+ / 8Mbps / 448 Kbps / Interleaving ON / Custom Thresholds.
Order will complete tomorrow, once completed it will need ccSNR to fix target SNRM at 12dB to stabilise the circuit."
So it looks as though he is putting you on an 8Mb product with Interleaving on as well as forcing your SNR Target to remain 12db which should complete tomorrow.
28-05-2014 3:07 PM
30-05-2014 7:05 AM
Uptime: 1 day, 3:07:43
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 446 / 4,441
Data Transferred (Sent/Received) [MB/MB]: 27.35 / 736.52
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 32.9 / 53.0
SN Margin (Up/Down) [dB]: 22.2 / 6.9
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 198 / 0
FEC Errors (Up/Down): 619 / 793,226
CRC Errors (Up/Down): 12 / 162
HEC Errors (Up/Down): 11 / 2,068 generateTasks()
Thanks, Mike
30-05-2014 9:47 AM
30-05-2014 10:57 AM
Was the capped US intentional or a facit of the manual process?
Kevin
30-05-2014 11:26 AM
30-05-2014 1:03 PM
Quote from: Mikejstephens DSL Type: ITU-T G.992.5
That shows the 8Mb rate cap is pretty worthless since it's still connected as ADSL2+ rather than ADSL2. My line achieves higher speeds by configuring the router to select ADSL2, rather than leaving it as auto and ending up as ADSL2+. (It has nothing to do with ADSL2+ using higher frequencies, none of which would ever be used on my line, probably something to do with different PSD masks being used, i.e. ADSL2+ adjusts the power levels for different tones differently.)
