Line Reset Required
FIXED- Subscribe to RSS Feed
- Line Reset Required
27-12-2023 7:40 PM - edited 27-12-2023 7:43 PM
Hi Guys/Girls
Router dropped off this morning twice, line has went bananas since at moment getting around 30 down lol ive tried everything i know technically but to no avail. Cant do the tests via text as it says mobile number not recognised to an account even though it is linked. No housephone installed we switched to no housephone.
Can one of you guys push a line reset please and run the tests on our line see if there is any faults showing from the heavy rain.
Cheers
Fixed! Go to the fix.
28-12-2023 9:46 AM
Morning @nufc1982 I've had a gander at the line and there is an external fault causing the issues so I have raised it to Openreach to sort it for you.
Re: Line Reset Required
28-12-2023 10:22 AM
Morning Will. Arrrr thought that might be a possibility also I know a while ago at end of street up pole there was some damage to the wire they repaired so possibly more water damage but anyways appreciate it pal hopefully get it sorted soon then.
28-12-2023 10:24 AM
28-12-2023 10:30 AM
Yeah, it's been pretty horrendous. Certainly here in Co Durham lol. Will do pal appreciate the quick help. 👍
28-12-2023 3:14 PM
Update - Engineer visit booked for January 2nd. Will update you after the visit.
